Thread: Dual Mass Fly Wheel symptoms???
Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 52
  1. Re: Dual Mass Fly Wheel symptoms???
    #21
    1841 Post(s)
    Manual or DSG?
  2. Re: Dual Mass Fly Wheel symptoms???
    #22
    Aug 2016
    london
    It's manual
    John.
  3. Re: Dual Mass Fly Wheel symptoms???
    #23
    Aug 2016
    london
    Quick update- the inlet flap is completely seized and needs replacing- not sure if that would cause the problem...?
    John.
  4. Re: Dual Mass Fly Wheel symptoms???
    #24
    1841 Post(s)
    It would make a rattling DMF sound even worse.
  5. Re: Dual Mass Fly Wheel symptoms???
    #25
    Apr 2016
    Ashburton
    I usually verify a duel mass clutch failure by trying to reverse up hill, usually a failing duel mass will cause the engine to stall when under load resulting in you needing to ride the clutch pedal to stop it stalling.
  6. Re: Dual Mass Fly Wheel symptoms???
    #26
    1841 Post(s)
    Quote Originally Posted by turboextreme View Post
    Yep, that should finish it off.......
  7. Re: Dual Mass Fly Wheel symptoms???
    #27
    Aug 2016
    london
    Ok but if the inlet flap/anti shudder valve is seized and not working, when you switch the engine off will that cause the shudder and because of the way it makes the engine act abnormally would it cause excessive strain on the dmf and in turn create a clunking noise? - even if it is in perfect condition?
  8. Re: Dual Mass Fly Wheel symptoms???
    #28
    1841 Post(s)
    No, even a brand new DMF will not rattle.
  9. Re: Dual Mass Fly Wheel symptoms???
    #29
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    87 Post(s)
    The ASV is self explanatory - when it's working it reduces shudder on shut down. When it's stuck open expect your b*lls to be shaken off when you stop the engine. Excess shudder / shaking can make a lot of things emit some strange noises. Had a DMF jam on a manual 2.0 CBDC a few months ago. Clutch bit at around 1cm from the floor, engine shook like it was on 3 cylinders, acceleration was non existent and fuel economy out the window. Had to drive it 60 miles to my garage on a busy Friday night at rush hour which took nearly 2 and a half hours. One of the worst driving experiences of my life and must have piffed off a lot of other drivers. Clutch was on the rivets, DMF scored then seized so had to be cut off. I found later that you can use a counter hold tool sometimes with a crank and flywheel lock to rotate the top plate back into position!
    Mad Mitch
  10. Re: Dual Mass Fly Wheel symptoms???
    #30
    Aug 2016
    london
    Thanks for all the information- new asv unit being fitted on Wednesday so I will report back.
  1. Dual Mass fly wheel conversion help please
    By winchman in forum Bora - 1998 - 2005
    Last Post: 21-01-2011, 08:16 PM
  2. Dual MAss Fly Wheel or Solid Mass Fly Wheel
    By Y90USF in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-02-2010, 08:32 PM
  3. Please Help New Clutch and Dual Mass Fly Wheel
    By A Rowley in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-02-2009, 09:05 PM
  4. Please Help dual mass fly,wheels
    By michael lynskey in forum Audi A3 - Archive Topics
    Last Post: 09-01-2009, 07:41 PM
  5. Question dual mass fly,wheels
    By michael lynskey in forum Chat - Anything with wheels
    Last Post: 30-12-2008, 05:39 PM
