Thread: Dual Mass Fly Wheel symptoms???
Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 52
  1. Re: Dual Mass Fly Wheel symptoms???
    Feb 2010
    Caithness
    Had a listen too and is a different sound from mine.
    When i start the engine then go to the bonnet I hear a definate clattering sound as if there are a few pieces of metal rattling around until it settles.
    Yours sounds no where near as exciting...yet mate if it is the DMF
    May 2012
    Italy
    Quote Originally Posted by martin1810 View Post
    I honestly can't tell. It does sound noisy but not so noisy that I would panic. I have old ears which don't help with noise diagnosis.
    I just noticed that turning off the AC the sound of the engine was OK. Perhaps the load of the AC compressor changed the sound making it somehow DMF-ish.
    My fellow mechanic told me to listen for a klang-klang sound when starting or stopping the engine.
    So far I am safe. Apologies for my over-thinking, but I have a BKP engine and that seems the worst thing VW engineered so far.
    Sent from my GT-N7000 using Tapatalk 2
    ~ Passat B6 2.0 TDI 140HP DSG Highline (12/2005) - in May 2012 had one injector failure (120000km) VW replaced all injectors for free ~
  3. Re: Dual Mass Fly Wheel symptoms???
    Jun 2012
    London
    Hi, I've just joined the forum to look for Dual Mass Flywheel issues. The video clip you've posted (#9) sounds just like my (2 year old - TDI blumotion) VW Sharan which is being investigated at dealership - thankfully still under warranty. Mechanic said they've found iron filings in gear oil and are stripping things down to identify where they came from. Last thing we expected from car with under 20K miles on clock.
    What's odd is gears seemed to be okay changing, rarely slipped and no unusual juddering. Main symptons of concern was the loud "tapping/rattling" noise when engine running in neutral - which would disappear when Clutch peddle pressed and noisy at traffic lights/stationery traffic. You could also hear the tapping/rattling at low speeds (30mph) with windows open and in gear.
    I wasn't sure whether to post this under the VW Sharan threads, put thought I'd comment on your question.
    I'm glad you got it sorted.
  4. Re: Dual Mass Fly Wheel symptoms???
    Norfolk
    Sounds like you have play in the gearbox input shaft, this often gets quieter when you depress the clutch.
  5. Re: Dual Mass Fly Wheel symptoms???
    DSG4ME Guest
    DMF sounds like pebbles in a washing machine, clutch action to stop it means as Martin said a layshaft or at best a thrust bearing.
  6. Re: Dual Mass Fly Wheel symptoms???
    Jun 2012
    London
    Thanks for info, would that also explain the iron filings in the gear box oil and what's likely to cause this in a newish car with low mileage?
    Interesting the garage's not suggested it yet.
  7. Re: Dual Mass Fly Wheel symptoms???
    #17
    Norfolk
    Quote Originally Posted by VWOwner5 View Post
    A worn bearing or a bearing turning in it's housing can cause the fault but not usually the iron filings. Occasionally a shaft will have faulty case hardening and then it wears very quickly, that is just random bad luck.
  8. Re: Dual Mass Fly Wheel symptoms???
    #18
    Jun 2012
    London
    Hi Martin, garage got back - Not a worn bearing. They said springs in clutch broken and caused damage to gear box as well. They've stripped everything and replacing with new clutch, but rebuilding the gear box - using parts on order from Germany. They're not sure when parts will arrive nore did they say which ones. I did suggested they just put a new gear box in since it's still under warranty, but they stuck to rebuilding it.
  9. Re: Dual Mass Fly Wheel symptoms???
    #19
    DSG4ME Guest
    I think theres some BS going on there, even if the springs are shot (which I guess they are) unless something has let go and made it's way into the gearbox there shouldn't be any need for GB work, and if that has happened they won't be re-building it anyway as it will need a new casing.
  10. Re: Dual Mass Fly Wheel symptoms???
    #20
    Aug 2016
    london
    Hi, I know this thread is old but am desperate to sort a problem- Audi A3 2l Tdi, 2005. When you switch the engine off there is a horrible rattle and nobody seems to be able to get to the bottom of it. Do you have any ideas?
    Thanks,
    John.
  1. Dual Mass fly wheel conversion help please
    By winchman in forum Bora - 1998 - 2005
    Last Post: 21-01-2011, 08:16 PM
  2. Dual MAss Fly Wheel or Solid Mass Fly Wheel
    By Y90USF in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-02-2010, 08:32 PM
  3. Please Help New Clutch and Dual Mass Fly Wheel
    By A Rowley in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-02-2009, 09:05 PM
  4. Please Help dual mass fly,wheels
    By michael lynskey in forum Audi A3 - Archive Topics
    Last Post: 09-01-2009, 07:41 PM
  5. Question dual mass fly,wheels
    By michael lynskey in forum Chat - Anything with wheels
    Last Post: 30-12-2008, 05:39 PM
