Thread: timing belt
  1. timing belt
    Jul 2007
    I recently had the timing belt changed on my seat toledo 1.9tdi. afterwards the engine started to make a whining noise. I think I know what this noise is from experiance doing some diy work on older cars. it seems to me that the belt is to tight. I talked to the man who fitted the belt and he said it would be ok. can anyone tell me if the belt can be adjusted or will the noise go away after time.
  2. Re: timing belt
    hi, the belt is whinning and is over tightened, if not adjusted to correct tention it is possible to run the bearings in the idler gear and whatever else the belt turns
    good luck!
  1. timing belt again
    By smiglyy in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 06-08-2007, 09:02 AM
  2. Cam belt timing belt tip , general
    By Conradvw in forum Archive posts
    Last Post: 11-01-2007, 04:29 PM
  3. Timing belt
    By splodge in forum Audi A3 - Archive Topics
    Last Post: 05-01-2007, 01:32 AM
  4. timing belt/ cam belt change
    By jonoallen in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 26-11-2006, 01:24 PM
  5. Timing Belt
    By hog883 in forum The Commercial Range
    Last Post: 06-03-2006, 10:12 PM
