Thread: 3.0tdi Allroad brake fault alarm on switch on.
Page 7 of 10 FirstFirst ... 56789 ... LastLast
Results 61 to 70 of 94
  1. Re: 3.0tdi Allroad brake fault alarm on switch on.
    #61
    Sep 2011
    Lurking over a keyboard ...
    Quote Originally Posted by sparker View Post
    Thank you again for everyones help with this. I sure you are all getting fed up with this thread as much as I am starting to get fed up with this problem.
    Keep your chin up mate... Sorry not done screenies, but glad you got MVB's done and we got A8 Tech
    Just another take on your thread...
    i) has educated you, me & others
    ii) fingers cross will solve yours or another's issue
    iii) think of how much diagnose money you could have forked out...
    I'm still having pause issue at startup ... no faults codes either
    I have been toying with idea of battery change.. even though no faults found by a workshop... relays was next thing...
    I'm hoping the workshop get to bottom of it whilst doing the chains...
    But I think now I'd just be happy with no chain rattle can live with pause at least nothing beeps or errors when this happen
  2. Re: 3.0tdi Allroad brake fault alarm on switch on.
    #62
    May 2007
    knee deep in clunge
    14 Post(s)
    I have added more info to my answer but from now on just post the fault events in full in the control units so its easier to work with
    I feel we have a corrupted control unit or insufficient voltage and that could be a sticking relay/bad earth/corroded contact causing resistance or the switch command from the ignition is briefly failing
    Now that could mean the switch, start authorisation control unit or simply a 15 relay failure but one thing we do no is the engine ecu drops out over the can and drive network so is it supply or consumer
    Must go now as I have a cambelt to fit
  3. Re: 3.0tdi Allroad brake fault alarm on switch on.
    #63
    Nov 2010
    Watford
    It's not the battery, new Audi Varta one fitted, coded OK, faults happened again second time I went to start the car. Turned the key to pos1 only.
    Turning the key off and then back to pos1, twice (before brake warning signal on DIS) corrected the problem car started perfectly with no other problem.
    Here is the latest log. Not sure if you just wanted the modules with faults listed or if this OK, sorry. Now cleared again.
    01-Engine -- Status: Sporadic communication error 1000
    02-Auto Trans -- Status: Malfunction 0010
    05-Acc/Start Auth. -- Status: OK 0000
    07-Control Head -- Status: OK 0000
    0E-Media Player 1 -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    34-Level Control -- Status: Malfunction 0010
    36-Seat Mem. Drvr -- Status: OK 0000
    37-Navigation -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    4F-Centr. Electr. II -- Status: Malfunction 0010
    53-Parking Brake -- Status: Malfunction 0010
    56-Radio -- Status: OK 0000
    61-Battery Regul. -- Status: OK 0000
    6C-Back-up Cam. -- Status: OK 0000
    76-Park Assist -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine Labels: Redir Fail!
    Part No SW: 4F0 910 402 S HW: 4F0 907 401 C
    Component: 3.0L V6TDI G000AG 0020
    Revision: --H03--- Serial number:
    Coding: 0011372
    Shop #: WSC 02334 785 00200
    VCID: 2D573FEDB40A1F1
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans Labels: 09L-927-760.lbl
    Part No SW: 4F2 910 156 K HW: 09L 927 156 C
    Component: AG6 09L 3,0 TDI RdW 0040
    Revision: --H01--- Serial number: 4236818
    Coding: 0000001
    2 Faults Found:
    006273 - Powertrain Data Bus: Missing Message
    P1881 - 000 - Acceleration Request - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 94811 km
    Time Indication: 0
    Date: 2012.07.07
    Time: 14:40:47
    Freeze Frame:
    RPM: 0 /min
    RPM: 0 /min
    RPM: 0 /min
    (no units): 30.0
    (no units): 25.0
    Temperature: 48.0∞C
    T.B. Angle: 60.0∞
    049408 - No Communication with Engine Control Module (SAE
    U0100 - 000 - ECM/PCM) - Intermittent
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 94811 km
    Time Indication: 0
    Date: 2012.07.07
    Time: 14:40:47
    Address 03: ABS Brakes Labels: 4F0-910-517.lbl
    Part No SW: 4F0 910 517 AB HW: 4F0 614 517 R
    Component: ESP 8.0 quattro H05 0040
    Revision: 00000000 Serial number: 00000000000000
    Coding: 0016776
    VCID: 64C19AC9A7409E9
    2 Faults Found:
    01314 - Engine Control Module
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 66
    Mileage: 94811 km
    Time Indication: 0
    Date: 2012.07.07
    Time: 14:40:54
    Freeze Frame:
    Hex Value: 0x0080
    Hex Value: 0x02A2
    Hex Value: 0x0013
    Hex Value: 0x8798
    Hex Value: 0x00FF
    02083 - Message for Delay Request
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 66
    Mileage: 94811 km
    Time Indication: 0
    Date: 2012.07.07
    Time: 14:40:54
    Freeze Frame:
    Hex Value: 0x0080
    Hex Value: 0x02A2
    Hex Value: 0x002B
    Hex Value: 0x0598
    Hex Value: 0x00FF
    Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
    Part No SW: 4F0 910 852 HW: 4F0 905 852 B
    Component: FBSAUDIC6 ELV H31 0220
    Revision: 31050601 Serial number: 10601100539500
    Coding: 0000147
    VCID: E3C319D5224E191
    Part No: 4F0 910 131 E
    Component: FBSAUDIC6 EZS H45 0080
    Part No: 4F0 910 220 D
    Component: FBSAUDIC6 IDG H01 0040
    Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
    Part No SW: 4F1 910 732 E HW: 4E0 035 729 A
    Component: Interfacebox H43 5570
    Revision: 00000000 Serial number: 351IP067525523
    Coding: 0003302
    Shop #: WSC 00720 210 91832
    VCID: 2645C0C191FC2C9
    Part No: 4F0 910 609 E
    Component: Bedienteil MMIC6H02 0060
    Address 08: Auto HVAC Labels: 4F0-910-043.lbl
    Part No SW: 4F0 910 043 HW: 4F2 820 043 N
    Component: KLIMABETAETIGUNGH20 0170
    Revision: 00000031 Serial number: 00000000313892
    Coding: 0001302
    VCID: DBB321351A3E211
    Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
    Part No SW: 4F0 910 279 K HW: 4F0 907 279
    Component: ILM Fahrer H15 0240
    Revision: 00000000 Serial number: 4F0907279
    Coding: 0001101
    Shop #: WSC 02335 785 00200
    VCID: 316F239DA8327B1
    Subsystem 1 - Part No: 4F2 910 113 B Labels: 1KX-955-119.CLB
    Component: Wischer AudiC6 H04 0190
    Coding: 00064784
    Shop #: WSC 02335
    Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
    Component: REGENLICHTSENSORH13 0090
    Coding: 00146221
    Shop #: WSC 02335
    Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
    Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
    Component: CD-Changer H44 0470
    Revision: 00000000 Serial number: AUZ5ZBF8194089
    Shop #: WSC 00000 000 00000
    VCID: 1C31E229DFB0E69
    Address 15: Airbags Labels: 4F0-910-655-8R.lbl
    Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
    Component: 4E AIRBAG AUDI8RH29 0280
    Revision: 08H29000 Serial number: 0037LD0GTURH
    Coding: 0013381
    Shop #: WSC 02325 785 00200
    VCID: 295FCBFD80E2031
    Address 16: Steering wheel Labels: 4F0-910-549.lbl
    Part No SW: 4F0 910 549 HW: 4F0 953 549 A
    Component: Lenks‰ulenmodul H08 0230
    Revision: 00H08000 Serial number: 90026062640222
    Coding: 0102142
    VCID: E6C500C1D17C6C9
    Part No: XXXXXXXXXXX
    Component: Lenkradmodul H07 0090
    Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
    Part No SW: 4F0 910 930 C HW: 4F0 920 981 F
    Component: KOMBIINSTR. M73 H18 0120
    Revision: 00500000 Serial number: 5HS37UK96
    Coding: 6185443
    Shop #: WSC 00402 210 13626
    VCID: 2343D9D5E2CED91
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 66
    Mileage: 94811 km
    Time Indication: 0
    Date: 2012.07.07
    Time: 14:40:48
    Address 19: CAN Gateway Labels: 4L0-910-468.lbl
    Part No SW: 4L0 910 468 A HW: 4L0 907 468 B
    Component: J533__Gateway H06 0060
    Revision: 00H06000 Serial number: 1100B0871980B4
    Coding: F5D1DE5F30320600
    Shop #: WSC 00016 210 69841
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 66
    Mileage: 94811 km
    Time Indication: 0
    Date: 2012.07.07
    Time: 14:40:47
    Address 34: Level Control Labels: None
    Part No SW: 4F0 910 553 A HW: 4F0 907 553 A
    Component: J197 LUFTFEDER H17 0060
    Serial number: 00619002170400
    Coding: 0000210
    VCID: 224DDCD1FDD4D09
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 66
    Mileage: 94811 km
    Time Indication: 0
    Date: 2012.07.07
    Time: 14:40:46
    01316 - ABS Control Module
    013 - Check DTC Memory - Intermittent
    Freeze Frame:
    Fault Status: 00101101
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 66
    Mileage: 94811 km
    Time Indication: 0
    Date: 2012.07.07
    Time: 14:40:54
    Address 36: Seat Mem. Drvr Labels: None
    Part No SW: 4F0 910 760 HW: 4F0 959 760
    Component: Sitzmemory FS H04 0050
    Revision: 00000000 Serial number: 00000000896400
    Coding: 0091138
    VCID: E1CF13DD38520B1
    Address 37: Navigation Labels: 4E0-910-88x-37.lbl
    Part No SW: 4E0 910 888 P HW: 4E0 919 887 D
    Component: MNS ECE H48 1060
    Revision: 00000000 Serial number: 364I+067593809
    VCID: 3B7301B57A7E811
    Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
    Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
    Component: TSG FA H12 0170
    Revision: 00000000 Serial number: gAò
    Coding: 0003738
    VCID: 2C5132E98F10169
    Address 46: Central Conv. Labels: 4F0-910-289.lbl
    Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
    Component: Komfortgeraet H22 0170
    Revision: 01700022 Serial number: 01017343460000
    Coding: 0262907
    VCID: 2E5538E1B90C649
    Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Part No: 4F0 910 177
    Component: Innenraumueberw.H01 0020
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 66
    Mileage: 94811 km
    Time Indication: 0
    Date: 2012.07.07
    Time: 14:40:54
    Address 47: Sound System Labels: 4F0-910-223-BO.lbl
    Part No SW: 4F0 910 223 J HW: 4F0 035 223 G
    Component: DSP-High C6 H09 0240
    Revision: PROD_01 Serial number: 00000000019540
    Coding: 0000113
    Shop #: WSC 00720 210 91851
    VCID: 2547C7CDECFA271
    Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
    Part No SW: 4F0 910 280 HW: 4F0 907 280 A
    Component: ILM Beifahrer H10 0080
    Revision: Serial number: 00000000287923
    Coding: 0001113
    VCID: DEB52821092C349
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 2
    Reset counter: 66
    Mileage: 94808 km
    Time Indication: 0
    Date: 2012.07.07
    Time: 14:40:00
    Freeze Frame:
    Voltage: 12.300 V
    Temperature: 35.0∞C
    Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
    Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
    Component: TSG BF H12 0170
    Revision: 00000000 Serial number: E4ó
    Coding: 0003738
    Address 53: Parking Brake Labels: 4F0-910-801.clb
    Part No SW: 4F0 910 801 B HW: 4F0 907 801 A
    Component: EPB CB4C0060 H04 0060
    Revision: --H04---
    Coding: 0000321
    Shop #: WSC 02324 785 00200
    VCID: 1F4BD525CEA6FD1
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 2
    Reset counter: 66
    Time Indication: 0
    Freeze Frame:
    Voltage: 11.39 V
    Count: 241
    Address 56: Radio Labels: 4E0-910-541.lbl
    Part No SW: 4E0 910 541 T HW: 4F0 035 541 H
    Component: TUNER EU/US/RDW H42 0630
    Revision: 00000000 Serial number: 384K-067627712
    Coding: 0000001
    Address 61: Battery Regul. Labels: 4F0-910-181.lbl
    Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
    Component: J0644 BEM H12 0590
    Revision: 00000000 Serial number: 00000000110730
    Shop #: WSC 00720 210 86430
    Subsystem 1 - Part No: 000 915 105 D
    Component: von VA0 320119J19A
    Coding: 30303039313531303544205641303332303131394A313941
    Shop #: WSC 12345 384 00290
    Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
    Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
    Component: TSG HL H21 0050
    Coding: 0003074
    Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
    Part No SW: 4F0 910 441 A HW: 4L0 907 441 A
    Component: J772__Rearview 0050
    Revision: --H12--- Serial number: 525PA8-J68305B
    Coding: 1020505
    VCID: 1E35E821C9ACF49
    Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
    Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
    Component: TSG HR H21 0050
    Coding: 0003074
    Address 76: Park Assist Labels: 4Fx-910-283.lbl
    Part No SW: 4F0 910 283 G HW: 4F0 919 283 G
    Component: Parkhilfe 8-Kan H12 0060
    Revision: 00H12000 Serial number: 06330626802621
    Coding: 0221416
    VCID: 2859CEF99BE83A9
    Address 77: Telephone Labels: 4E0-910-336.lbl
    Part No SW: 4E0 910 336 H HW: 4E0 862 335
    Component: Handyvorb2 H13 0700
    Revision: 00000000 Serial number: 00000007577872
    Coding: 0010920
    VCID: 275BCDC596F6351
    Audi Allroad 3.0tdi. Tiptronic. 12/12/2006. Full Phantom Black, 19" alloys, MMI high, Navigation, Phone prep, Heated sports seats with memory, Parking advanced with rear camera, Sunroof, Rear blinds.
  4. Re: 3.0tdi Allroad brake fault alarm on switch on.
    #64
    May 2007
    knee deep in clunge
    14 Post(s)
    so no alarm trigger and the engine starts ok now?
    if so we just have the dash warning error?
    if you just try to start as normal what happens ?
    connect vcds turn ignition to position 1 goto address 19 mvb 200 read out the 15 (position 1 for the key) feedback when the error occurs
    also in 19 look at 125 126 see if you have a flickering 0/1 status on any of the drive can control units showing coms errors
    ideally you are looking for a 0 (can off) to isolate the control unit corrupting the drive can signal or can wire/connection
  5. Re: 3.0tdi Allroad brake fault alarm on switch on.
    #65
    Nov 2010
    Watford
    I seem to have confused things a little. The brake warning on the DIS and the alarm bleep to notify you of the problem come on a few seconds after I turn the key to Pos 1. I know the fault has occurred before this when the glow plug light stays on and all the other warning lights also stay on. When I see that happen I turn the key back to off, if I left key at Pos 1 the brake warning will sound.
    Next time it happens (which at this rate won't be long) I will record the dater on those MVB's in address 19 and post.
    If I try to start the car what happens? Last time I tried to start the car with this fault the engine turned over and continued to turn over after releasing the key, it did not start. The engine was hot after a short journey. Previous attempts to start have mostly been short and unsuccessful but it has also started once or twice with a cloud of smoke, I ran the car briefly turned off and it restarted perfectly as the fault had gone.
    I had put this behaviour down to the glow plug circuit not being active when the fault occurs. If the 3.0tdi engine is warm should it start OK without glow plugs or are glow plugs always critical for starting?
    If the fuel pump relay J317 was not working properly could the car still start at all? Is it operating a low pressure fuel pump from the tank or a high pressure injection pump on the engine?
    Will try starting it again next time after reading the codes.
  6. Re: 3.0tdi Allroad brake fault alarm on switch on.
    #66
    Nov 2010
    Watford
    See edited previous post about starting.
    Latest results.
    So, this time I recorded the mvb's which took a few minuets all the lights on the dash stayed on esp,abs, level and the brake warning on dash with three bleeps. The glow plug light had stayed on but by the time I had read the codes this light was out. Went to start the car and it started perfectly. All the other warning lights stayed on until I cleared the codes(engine running)
    The results of the mvb's don't show any problems with control units at the time of test, all are recording 1.
    So I think no joy there.
    The battery looks to be low 12V and 12.10V, 12.2 recorded on my meter at the battery. Should be higher but not sure what the charge of the new battery was and haven't been on a long journey. Anyway I recorded the battery and charge MVB's in add 61, at tick over. The battery meter showed just over 14v at battery with car ticking over.
    Battery back on charge
    Results
    Address 19: CAN Gateway (4L0 910 468 A)
    11:59:05 Group 200
    12.00 V Voltage
    12.10 V Voltage
    0 Error Code
    11:59:05 Group 125
    Engine 1
    Transm. 1
    ABS 1
    11:59:05 Group 126
    Airbag 1
    Level 1
    Park Brake 1
    01-Engine -- Status: Malfunction 1010
    61-Battery Regul. -- Status: Malfunction 0010
    Coding: 0011372
    1 Fault Found:
    005715 - Please check DTC Memory of ABS Controller
    P1653 - 001 -
    Freeze Frame:
    Fault Status: 01100001
    Fault Priority: 0
    Fault Frequency: 1
    Time Indication: 0
    Freeze Frame:
    RPM: 0 /min
    Torque: -195.0 Nm
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 11.70 V
    Bin. Bits: 00101000
    Torque: 0.0 Nm
    Coding: 0000001
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 94819 km
    Time Indication: 0
    Date: 2012.07.08
    Time: 11:55:44
    Freeze Frame:
    RPM: 0 /min
    RPM: 0 /min
    RPM: 0 /min
    (no units): 30.0
    (no units): 25.0
    Temperature: 20.0∞C
    T.B. Angle: 60.0∞
    050177 - Implausible Data Received from Engine Control Module
    U0401 - 000 - - Intermittent
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 94819 km
    Time Indication: 0
    Date: 2012.07.08
    Time: 11:55:44
    Coding: 0016776
    2 Faults Found:
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 27
    Mileage: 94819 km
    Time Indication: 0
    Date: 2012.07.08
    Time: 11:55:48
    Freeze Frame:
    Hex Value: 0x0080
    Hex Value: 0x02A2
    Hex Value: 0x0013
    Hex Value: 0x8595
    Hex Value: 0x00FF
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 27
    Mileage: 94819 km
    Time Indication: 0
    Date: 2012.07.08
    Time: 11:55:46
    Freeze Frame:
    Hex Value: 0x0080
    Hex Value: 0x02A2
    Hex Value: 0x002B
    Hex Value: 0x0595
    Hex Value: 0x00FF
    Coding: 0000147
    Coding: 0003302
    Coding: 0001302
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 67
    Mileage: 94819 km
    Time Indication: 0
    Date: 2012.07.08
    Time: 11:55:53
    Coding: 0001101
    Coding: 00064784
    Shop #: WSC 02335
    Coding: 00146221
    Shop #: WSC 02335
    Coding: 0013381
    Coding: 0102142
    Coding: 6185443
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 67
    Mileage: 94819 km
    Time Indication: 0
    Date: 2012.07.08
    Time: 11:55:46
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 67
    Mileage: 94819 km
    Time Indication: 0
    Date: 2012.07.08
    Time: 11:55:44
    Coding: 0000210
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 67
    Mileage: 94819 km
    Time Indication: 0
    Date: 2012.07.08
    Time: 11:55:43
    013 - Check DTC Memory - MIL ON
    Freeze Frame:
    Fault Status: 11101101
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 27
    Mileage: 94819 km
    Time Indication: 0
    Date: 2012.07.08
    Time: 11:55:46
    Coding: 0091138
    Coding: 0003738
    Coding: 0262907
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 67
    Mileage: 94819 km
    Time Indication: 0
    Date: 2012.07.08
    Time: 11:55:46
    Coding: 0000113
    Coding: 0001113
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 67
    Mileage: 94816 km
    Time Indication: 0
    Date: 2012.07.08
    Time: 11:55:00
    Freeze Frame:
    Voltage: 12.100 V
    Temperature: 17.0∞C
    Coding: 0003738
    Revision: --H04---
    Coding: 0000321
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 67
    Time Indication: 0
    Freeze Frame:
    Voltage: 11.18 V
    Count: 241
    Coding: 0000001
    1 Fault Found:
    01299 - Diagnostic Interface for Data Bus (J533)
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 67
    Mileage: 94819 km
    Time Indication: 0
    Date: 2012.07.08
    Time: 11:55:48
    Coding: 0003074
    Coding: 1020505
    Coding: 0003074
    Coding: 0221416
    Coding: 0010920
    Sunday,08,July,2012,12:06:38:15171
    VCDS Version: Release 11.11.3
    Data version: 20120401
    Address 61: Battery Regul. (4F0 910 181 E)
    12:06:29 Group 001: Basic Functions
    14.30 V Generator Voltage (specified)
    14.00 V Battery Voltage (actual)
    32.3 % Dynamic-Field Signal
    0.00 s Load Response Time
    12:06:29 Group 002: Battery Temperatures && Shut-Off Stages
    33.0∞C Rail Temperature (actual)
    16.0∞C Battery Temp. (valuation)
    ConsSwOff 0 Emergency Shut-Off
    StatCurStg 0 Static-Current Shut-Off Stage
    12:06:29 Group 003: Battery Status I
    100.0 % Battery Condition
    5 ohms Internal Battery Resistance
    0 Ah Qv (Battery Aging)
    0 Ah Charge
    Sunday,08,July,2012,12:09:37:15171
  7. Re: 3.0tdi Allroad brake fault alarm on switch on.
    #67
    Sep 2011
    This is my take on glow plug light... just like the other lights in cluster it must light up just to show it is working..
    I think on my VW only in winter did I see it stay on longer than the other lights in cluster and it was negative outside temp if my memory serve me correct...
    I had my car now 11mths, it was about 3mths in that chain rattle start then starter pause started happening...
    Usually when I initiate starting of car when pause occur car turns over for a second then stop turning for second then starter kick in again and it start with nothing more then the occasional smokey exhaust due to outside temp or what normal for desiel when cold and first start...
    Only about 4-5 times sporadically car over my current ownership period it would not even initiate starter... but no faults, if turn key back to removal position and started start process again everything work ok...
    I have tried starting my car instantly when get in wait for no lights to go out on cluster and always start quickly regardless of first start of day/ car hot or cold...
    If wait for lights to switch off again no noticeable difference first start of day/car hot or cold...
    Again only my understanding for when looking into chain rattle high pressure pump is mechanically powered and has elec.control and relay is for the low pressure pump from the tank...
  8. Re: 3.0tdi Allroad brake fault alarm on switch on.
    #68
    Nov 2010
    Watford
    Hi Gupsterg,
    The glow plug light does behave differently. I know the fault is coming as soon as I turn the key to Pos 1 because the glow plug doesn't come on straight away with the other lights, there is a second delay then it comes on and stays on. Now I don't know how long it stays on for, but some time.
    I had seen on Audi portal, that yes indeed the 317 relay does power the tank pump. I was wondering if this relay was playing up could the car still run be it briefly. I think it's not starting because of the glow plugs and what ever is causing the problem is a brief blip. Once the glow plugs had operated and the glow plug light went out the car started no problems. It is interesting that you think your car starts fine without the glow plugs having time to work but they could still be super hot as the car is turning over and heating the diesel.
    What I do know is that this is the first time the car has started fine when it has this problem and it is the first time I left it lit up that long. So J317 not working throwing up faults, with no diesel won't start, then J317 starts working again? Or glow plugs not switching on because of completely different problem and won't start? Or both? Or neither?
    Has the problem already cleared itself when I checked the MVB's????
    Common problem here is all the question marks in this post!!!!
    Again mind working over time but not really having any clue.
    Hope the expert v8tech is able to help further. Change a relay or two and see what happens?
    New battery on charge today and reading 12.9V now.
  9. Re: 3.0tdi Allroad brake fault alarm on switch on.
    #69
    May 2007
    knee deep in clunge
    14 Post(s)
    you need to check the ecu switched earth as mentioned yesterday and also the voltage input and earth to the engine ecu
    the engine has no error but the control units on the can and drive are having problems hence the brief warning and fault codes for missing command
    you have either a voltage interruption or network error
    as the engine ecu is fault free
    look at these in engine ecu address 01
    125 CAN communication
    1) CAN communic. Automatic gearbox
    2) CAN communic. ABS/ESP
    3) CAN communic. Instrument cluster
    4) CAN communic. AC
    0 = inactive
    1 = active
    126 CAN communication
    1) CAN communic. ACC
    2) Vacant
    3) CAN communic. Airbag
    4) Vacant
    0 = inactive
    1 = active
    127 CAN communication
    1) Vacant
    2) Vacant
    3) CAN communic. Steering column module
    4) Vacant
    0 = inactive
    1 = active
    129 CAN communication
    1) CAN communic. Battery energy management
    2) CAN communic. Gateway
    3) Vacant
    4) Vacant
    0 = inactive
    1 = active
    CAN = Controller Area Network
    The CAN bus is a network for local interconnection of
    control units.
    ignition switch in address 01
    095 Starter control
    1) Terminal 50
    0 or 1
    2) P/N signal
    Only vehicles with automatic gearbox
    Signal from selector lever switch
    Interlock signal
    Only vehicles with manual gearbox
    Signal from clutch pedal switch for engine start
    0 or 1
    3) Starter relay 1
    0 or 1
    4) Starter relay 2
    0 or 1
    096 Starter control
    1) Terminal 50-back
    0 or 1
    2) Starter control shut-off conditions 1 (from 11.2005)
    X X X X X X X 1 Fault starter relay
    X X X X X X 1 X Fault P/N or interlock signal
    3) Starter control shut-off conditions 2
    X X X X X X X 1 Start rejection speed reached
    X X X X X X 1 X Road speed threshold
    surpassed
    X X X X X 1 X X Maximum start time depending on glow period
    surpassed
    X X X X 1 X X X Maximum start time exceeded
    X X X 1 X X X X Terminal 15 deactivated
    X X 1 X X X X X Terminal 15 lock
    X 1 X X X X X X Terminal 50 or 50-back missing
    1 X X X X X X X Starter activated, but engine
    speed is 0 rpm
    4)Vehicle voltage
    [V]
  10. Re: 3.0tdi Allroad brake fault alarm on switch on.
    #70
    Nov 2010
    Watford
    Just an update,
    I have charge the battery fully, it was up over 13Volts
    Also I checked the earths for the ecu (I believe). One on top of bulk head by expansion vessel and one plug in the wiring loom located slightly to driver side clipped to rear top of bulk head. Also found another earth point below brake master cylinder in bottom of plenum chamber. All these looked clean and had zero corrosion.
    Didn't know how to check the switch earth etc. So I have replaced relay J317 (614 on it) part no. 8EO 951 253 in position 3 under ecu.
    I will obviously let you now how things go in the coming weeks, hopefully fingers crossed you won't here from me for a while. No news will be good news!
  1. Allroad Electric Mirror Switch
    By WesleyP in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 24-11-2011, 02:49 PM
  2. Fault codes - brake light switch
    By rabbie1969 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-08-2011, 06:31 PM
  3. Question Brake Switch Fault P0571/16955
    By vfrvulcan in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-05-2011, 09:17 PM
  4. Please Help Brake switch and brake pressure sensor issue??
    By P.M.G in forum Audi A3 - Archive Topics
    Last Post: 07-02-2009, 06:20 PM
  5. brake lights / brake switch recurring nightmare!
    By stuart40 in forum Chat - Anything with wheels
    Last Post: 16-09-2007, 11:23 PM
