Thread: A4 Quattro Servicing Tasks
  1. A4 Quattro Servicing Tasks
    Mar 2007
    Hi. Does anyone know of a list of all the checks and or part replacements that need to be done at the service intervals or after certain mileages? I have been looking for a while but havent had any luck. I have a 1997 1.9tdi avant quattro.
    Graeme
  2. Re: A4 Quattro Servicing Tasks
    May 2007
    knee deep in clunge
    14 Post(s)
    Maintenance list
    Order number Type Code First registration
    Vehicle identification number Engine code EC Mileage Service consultants
    Model name Gear Model year Date
    Inspection service 30,000 km
    Use the "Strict maintenance procedures" at all times
    Electrics OK / completed Not OK Rectified
    Front lights - Check function: Side lights, dipped beam, main beam, fog lights, turn signals, hazard warning lights
    Rear lights - check function: Brake lights (including 3rd brake light), tail lights, reversing lights, rear fog light, number plate light, turn signals, hazard warning lights
    Interior glove compartment light, warning lamps, horn and luggage compartment light: Check function
    Read fault memory
    Service display: Reset
    Vehicle exterior OK / completed Not OK Rectified
    Door arrester, lock cylinder and bonnet catch: Grease
    Windscreen wiper blade park position: Check, adjust setting angle only if wiper blades "judder"
    Windscreen wiper blades: Check for damage - change in consultation with customer
    Tyres OK / completed Not OK Rectified
    FL wheel: Check condition and wear pattern of tyre; enter tread depth mm
    RL wheel: Check condition and wear pattern of tyre; enter tread depth mm
    Spare wheel: Check condition, inflation pressure and wear pattern of tyre; enter tread depth mm
    RR wheel: Check condition and wear pattern of tyre; enter tread depth mm
    FR wheel: Check condition and wear pattern of tyre; enter tread depth mm
    Vehicle from below OK / completed Not OK Rectified
    Engine, gearbox, final drive, steering, protective bellows: Visual check for leaks and damage
    Manual gearbox: Check oil level, top-up with oil if necessary
    Engine oil: Drain or extract, renew oil filter
    Brake pads/linings: Check thickness of brake pads
    Brake system: Visual check for leaks and damage
    Track rod ends: Check play, security and boots
    Swivel joints: Check swivel joint boots for leaks and damage
    Exhaust system: Visual check for leaks, security and damage
    Underbody: Visual check for damage, observe loose securing parts and lines.
    Engine compartment OK / completed Not OK Rectified
    Engine and engine compartment: Visual check for leaks and damage
    Engine oil: Replenish (after replenishing top-up to max. mark if necessary), VW standard VW 505 00, VW 505 01; Füllmenge 3,80 litre
    Battery: Check
    Hydraulics: Check oil level and for leaks, replenish hydraulic oil if necessary
    Plenum chamber and water drain valve: Check for soiling and clean if necessary
    Air filter: Clean air filter housing and renew filter element
    Dust and pollen filter/odour air pollution filter: Renew
    Camshaft drive toothed belt: Check for damage, measure width of belt
    Changing brake fluid; Never remove strainer from brake fluid reservoir
    Fuel filter: Renew
    Final checks OK / completed Not OK Rectified
    Tyre pressure of both front wheels: Check bar
    Tyre pressure of both rear wheels: Check bar
    Road test: Perform test
    = Additional work with special invoice
    OK / completed = OK Not OK = Not OK, please observe maintenance instructions Rectified = The error has been rectified
    Notes
    Inspection Service
    Inspection Service due according to service interval display (non-flexible) Page
    – Oil Change Service
    (every 12 months or every 15,000 km/10,000 miles) → Chapter
    – Inspection Service
    (every 30,000 km/20,000 miles, oil change and additional work is included) → Chapter
    – Brake fluid change every 2 years
    → Chapter
    Notet For petrol engines use oils according to specification -VW 500 00-, -VW 501 01- or -VW 502 00- and for diesel engines oils according to specification -VW 505 00- or -VW 505 01-. The service interval display must then be programmed to non-flexible. (Oil grade 1)
    t Only the Inspection Service is available (non-flexible) for vehicles with 1.9 ltr. TDI engine (unit injector). Use oil according to VW standard -505 01- on these engines.
    Service → Note Interval Work to be completed Page
    In 1 every 12 months All work to be completed, except for jobs marked "X/XX"
    In 1 every 12 months In addition to Inspection Service “Work to be completed Audi A4 duo”– Workshop Manual Audi A4 1995 duo; Booklet for duo service providers Edition 10.98; Work to be completed/description of work
    In 1 every 30,000 km (20,000 miles) Jobs required every 12 months, including those marked with an X
    In 1 every 60,000 km (40,000 miles) Jobs required every 12 months, including those marked with an X/XX
    In 1 every 60,000 km (40,000 miles) In addition to Inspection Service:– Toothed belt and tensioning roller for camshaft drive: renewing (4-cyl. TDI engine AHH, up to and incl. model year 1999 -X-)
    → Chapter
    – Toothed belt for camshaft drive: checking for damage (2.6 ltr. 2V engines and 2.8 ltr. 2V engines).
    → Chapter
    – Toothed belt: renewing, use repair kit (V6 2.7 ltr. engine ASJ, AZR)
    → Chapter
    In 1 every 90,000 km (60,000 miles) In addition to Inspection Service:– Toothed belt and tensioning roller for camshaft drive: renewing (4-cyl. TDI engines; except for engine AHH)
    → Chapter
    – Toothed belt for camshaft drive: renewing (4-cyl. TDI engine AHH, from model year 2000 -Y-)
    → Chapter
    – Toothed belt and tensioning roller for camshaft drive: renewing (4-cyl. TDI engines with unit injector)
    → Chapter
    In 1 every 120,000 km (80,000 miles)
    or after max. 5 years In addition to Inspection Service:– Toothed belt: renewing, use repair kit (4-cyl. 5V 1.8 ltr. engines up to model year 1997 -V-)
    → Chapter
    – Toothed belt: renewing (4-cyl. 5V 1.8 ltr. engines model year 1998 -W- and 1999 -X-)
    → Chapter
    – Toothed belt: renewing, use repair kit (4-cyl. 5V 1.8 ltr. turbocharged engines up to model year 1999 -X-)
    → Chapter
    – Toothed belt and tensioning roller: renewing; checking water pump and renewing if necessary (2.4 ltr. 5V V6 petrol engines up to model year 2000 -Y-)
    → Chapter
    – Toothed belt and tensioning roller: renewing; checking water pump and renewing if necessary (2.8 ltr. 5V V6 petrol engines up to model year 2000 -Y-)
    → Chapter
    – Toothed belt: renewing; checking water pump and renewing if necessary (V6 2.7 ltr. engines AGB, AZB up to model year 2000 -Y-)
    → Chapter
    In 1 every 120,000 km (80,000 miles) In addition to Inspection Service:– V-belt and poly V-belt: renewing (4-cyl. petrol engines ADP, ADR, AEB, AFY, AJL, ANB, APT, APU, ARG)
    → Chapter
    – Poly V-belt: renewing (4-cyl. petrol engines AHL, ARM, ANA)
    → Chapter
    – Poly V-belt: renewing (V6 petrol engines)
    → Chapter
    – Toothed belt: renewing, (4-cyl. 5V 1.8 ltr. turbocharged engines from model year 2000 -Y-)
    → Chapter
    – Toothed belt and tensioning roller: renewing (2.4 ltr. 5V V6 petrol engines from model year 2001 -1-)
    → Chapter
    – Toothed belt: renewing, use repair kit (V6 2.7 ltr. engines AGB, AZB from model year 2001 -1-)
    → Chapter
    – Toothed belt and tensioning roller: renewing (2.8 ltr. 5V V6 petrol engines from model year 2001 -1-)
    → Chapter
    – Toothed belt for camshaft drive and toothed belt for injection pump: renewing (V6 TDI engines)
    → Chapter
    In 1 every 180,000 km (115,000 miles) In addition to Inspection Service:– Toothed belt for camshaft drive: renewing, (4-cyl. 5V 1.8 ltr. engines from model year 2000 -Y-) → Note
    → Chapter
    In 1 → Note
    In 2 → Note every 24 months In addition to Inspection Service:– Brake fluid: changing
    → Chapter
    1) Service due according to service interval display
    2) Up to model year 1999 -X- every 60,000 km/40,000 miles; from model year 2000 -Y- every 90,000 km
    3) From model year 1998
    4) Up to model year 1997
    5) As from model year 2000 -Y- every 180,000 km (115,000 miles) (except for turbocharged engines).
    Electrical system
    Note: From model year 2000 -Y- the Inspection Service, previously due every 12 months, is no longer required (HST, Chapter 6, Inspection and Maintenance)
    Perform oil change service. Perform Inspection Service after 30,000 km/20,000 miles or 2 years
    Front lighting - checking operation: side lights, dipped headlights, main beam headlights, fog lights, turn signals, hazard warning lights
    Rear lighting - checking operation: brake lights (incl. 3rd brake light), rear lights, reversing lights, rear fog light, number plate lights, turn signals, hazard warning lights, luggage compartment light
    Interior lights and glove box lights, warning and indicator lamps, horn: checking operation
    Self-diagnosis: interrogating fault memory with fault reader -V.A.G 1551- or -VAS 5051- → Chapter
    Service interval display: resetting on models up to and including model year 1999 -X- → Chapter
    Service interval display: resetting Inspection Service as from model year 2000 -Y- → Chapter
    Vehicle, from outside
    Door arresters and lock cylinders: lubricating → Chapter
    Rear lid hinges: lubricating → Chapter
    X Sun roof: checking operation, cleaning guide rails and spraying with lubricating spray → Chapter
    Windscreen wiper/washer system and headlight washer system: checking jet settings and operation → Chapter
    Wiper blades in park position: checking → Chapter
    Only in the case of “juddering” wiper blades: checking setting angle → Chapter
    Wiper blades: checking for damage
    Tyres
    Tyre on spare wheel: checking condition and wear pattern; entering tread depth → Chapter
    Tyre (front left): checking condition and wear pattern; entering tread depth → Chapter
    Tyre (rear left): checking condition and wear pattern; entering tread depth → Chapter
    Tyre (rear right): checking condition and wear pattern; entering tread depth → Chapter
    Tyre (front right): checking condition and wear pattern; entering tread depth → Chapter
    Vehicle, from below:
    Engine, gearbox, final drive, steering and boots: visual checks for leaks and damage
    Engine oil: draining or extracting, changing oil filter → Chapter
    X Manual gearbox/final drive: checking oil level, topping up with oil if necessary → Chapter
    XX Final drive (automatic gearbox): checking oil level, topping up with oil if necessary → Chapter
    Brake system: visual check for leaks and damage → Chapter
    Brake pads: checking thickness → Chapter
    X Underseal: visual check for damage → Chapter
    Exhaust system: visual check for leaks and damage, check that parts are properly secured
    Track rod ball joints: checking play, security and boots → Chapter
    Swivel joints: checking boots for leaks and damage
    Engine compartment
    Engine (from above) and engine compartment: visual check for leaks and damage → Chapter
    Engine oil: filling up → Chapter
    XX Crankcase pressure: checking (V6 TDI engines)
    Not required on AFB engine from engine number 154 592 onwards
    Not required on AKN engine from engine number 031 890 onwards → Chapter
    Battery: checking electrolyte level, topping up with distilled water if necessary → Chapter
    Windscreen and headlight washer system: topping up with washer fluid → Chapter
    Cooling system: checking antifreeze and coolant level / antifreeze specified value -25°C; actual value (measured value): → Chapter
    XX Hydraulic system: checking for leaks, checking hydraulic fluid level and topping up if necessary → Chapter
    XX Air cleaner housing and snow strainer: cleaning; renewing filter element → Chapter
    XX Spark plugs: renewing → Chapter
    Fuel filter: renewing (TDI engines) → Chapter
    X Fuel filter: draining water (TDI engines up to and including model year 1999 -X-) → Chapter
    X Dust and pollen filter: renewing → Chapter
    Poly V-belt: renewing (according to mileage/km) - additional work → Chapter
    XX Toothed belt for camshaft drive: checking for damage (2.6 ltr. 2V engines and 2.8 ltr. 2V engines) → Chapter
    Toothed belt for camshaft drive: checking for damage, measuring width of toothed belt
    (4-cyl. TDI engines up to and including model year 1999 -X-) → Chapter
    X Toothed belt for camshaft drive: checking for damage, checking tension, tensioning belt if necessary (V6 TDI engines) - additional work → Chapter
    X Toothed belt for injection pump: checking for damage, checking tension, tensioning belt if necessary (V6 TDI engines) - additional work → Chapter
    Toothed belt: renewing (according to mileage/km) - additional work
    Use additional parts or repair kit if necessary → Chapter
    V-belt and poly V-belt: renewing (according to mileage) - additional work → Chapter
    Checking that toothed belt was renewed. If toothed belt was not renewed: renewing - additional work
    Brake fluid level (depends on brake pad wear): checking → Chapter
    Brake fluid: changing (every two years) - additional work
    - Note: Never remove strainer from brake fluid reservoir → Chapter
    Final jobs
    Tyre pressures on all 4 wheels and spare wheel: checking → Chapter
    X Headlights: checking settings and adjusting if necessary (ellipsoid headlights) → Chapter
    X Headlights: checking settings and adjusting if necessary (gaseous discharge headlight) → Chapter
    Audi sticker: entering next service (and date for brake fluid change. Affixing sticker to left side of dash panel or to door post (B-pillar) → Chapter
    Road test → Chapter
    __________________________ __________________________
  3. Re: A4 Quattro Servicing Tasks
    Mar 2007
    Thanks for the quick response mate!
  1. Variable servicing
    By Firsttime Audi in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 14-06-2007, 11:29 PM
  2. Own Car Servicing
    By dogbolter47 in forum Polo - Derby - Lupo - Fox
    Last Post: 21-04-2007, 04:08 PM
  3. Servicing help A3 Quattro 2000 model
    By spadey in forum Audi A3 - Archive Topics
    Last Post: 03-04-2007, 04:30 PM
  4. Servicing help A3 Quattro 2000 model
    Last Post: 02-04-2007, 05:32 PM
  5. Servicing
    By ameldridge in forum Passat - Archive Topics
    Last Post: 11-12-2006, 06:34 PM
