Thread: blowing cold air only
  1. blowing cold air only
    May 2012
    Dublin
    Hi all
    My heater is only blowing cold air, Not even luke warm air, I drive a 2.0tdi 2008, I'm Freezing while driving around in MAY!! Any suggestions? There's enough coolant in the rad reserve bottle etc.
  2. Re: blowing cold air only
    UK Ex-pat now in Australia
    You will need to see if the 2x pipes going to the heater matrix are getting hot - it may be a circulation fault due to faulty pump/thermostat. It may also be a problem with the heater control flap motors which may come up as fault codes - you may need to get a diagnostic session carried out on the car in order to point you in the right direction 1st.
    Had MKV GTI, Now Ford Falcon
  3. Re: blowing cold air only
    May 2012
    Dublin
    Are the heater flap motors located behind the radio console, if so how do I remove the console to check them?
  4. Re: blowing cold air only
    You may need to check them using VW diagnostic machine.
  1. 1997 A4 A/C NOT blowing cold air
    By gotsA4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 07-08-2011, 09:35 PM
  2. Please Help Heater Blowing Cold Air
    By HeliPilot in forum Golf MK5 - 2004 - 2009
    Last Post: 12-12-2010, 08:22 PM
  3. Engine fan comes on at cold start, heaters blowing cold air when idle
    By walsie in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-12-2010, 07:26 PM
  4. B5 A4 Blowing Cold Air
    By redstarling1 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-04-2009, 12:44 PM
  5. Please Help 97-A4TDi Blowing Cold Air
    By Strollingby in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 31-08-2008, 12:30 AM
