Thread: Passat 1.9 TDI B6 wont start "Engine Emission" Vagcom Enginer Speed Sensor G28
  1. Passat 1.9 TDI B6 wont start "Engine Emission" Vagcom Enginer Speed Sensor G28
    Jan 2012
    newcastle upon tyne
    Hi All, My car Passat 1.9 TDI b6 3C was running fine till I went to shopping yesterday. parked my car fine in multistory car on 10th floor.
    came back from shopping and car wont start. It tries to start but ...Message appears "Emission Garage" called recovery and before recover Arrived I did the vagcom and it says
    Address 01: Engine Labels: 03G-906-016-BKC.lbl
    Part No SW: 03G 906 021 DP HW: 028 101 274 2
    Component: R4 1,9L EDC G000SG 7870
    Revision: --H01--- Serial number: VWZCZ000000000
    Coding: 0000071
    Shop #: WSC 00028 028 00001
    VCID: 70E4D29E5CF9059C
    2 Faults Found
    005659 - Glowplug for Cylinder 2 (Q11): Open Circuit
    P161B - 000 - -
    Freeze Frame:
    Fault Status: 01110000
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 154434 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 11:28:30
    Freeze Frame:
    RPM: 882 /min
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 14.44 V
    Bin. Bits: 00001100
    Temperature: 15.3°C
    Bin. Bits: 10110000
    [color=#FF0040]000802 - Engine Speed Sensor (G28): No Signal
    P0322 - 000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00110000
    Fault Priority: 0
    Fault Frequency: 5
    Mileage: 157134 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 13:57:18
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 11.10 V
    Bin. Bits: 00001100
    Idle Stabilization: 0.0°KW
    RPM: 126 /min
    [/COLOR]
    Readiness: 1 1 0 0 0
    Please help what it is? Expensive? Is it realy only a sensor? Where is it located in Passat B6 1.9 TDI 3c?
  2. Re: Passat 1.9 TDI B6 wont start "Engine Emission" Vagcom Enginer Speed Sensor G28
    london/ UK
    Did you have any work done on the engine recently ? Engine speed sensor is also known as crankshaft sensor- look on the gearbox bell housing. You filled the tank with diesel prior that ? I suggest you look at the receipt and make sure the tank does not smell of petrol ! Also check the cambelt condition...
  3. Re: Passat 1.9 TDI B6 wont start "Engine Emission" Vagcom Enginer Speed Sensor G28
    Jan 2012
    newcastle upon tyne
    thanks adam. I had low level of fuel but not tha low and for sure it had diesel not petrol. I opend the bonnet this morning and pressed all connectore with hand i could see in there. tried and car started but still had the "emission garage" message. then I went to garage and put about 20 litre diesel in. after 4 or 5 starts "emission garage" message dissappeared. now no msgs and car running fine. any suggestion? im scared if it let me down again. time belt was done about 47k ago. cant gurantee as I didnt do it. only trusting paper work from previous seller.
  4. Re: Passat 1.9 TDI B6 wont start "Engine Emission" Vagcom Enginer Speed Sensor G28
    Jan 2012
    newcastle upon tyne
    sorry forgot to mention i had headlight replaced after a small crush. it happend immediately after that.
  5. Re: Passat 1.9 TDI B6 wont start "Engine Emission" Vagcom Enginer Speed Sensor G28
    london/ UK
    Doubt headlight has anything to do with it, i still suspect you put petrol in it !
  1. How To G28 Engine Speed Sensor
    By Silver in forum Polo - Derby - Lupo - Fox
    Last Post: 25-09-2016, 03:34 PM
  2. Replies: 21
    Last Post: 04-07-2012, 10:32 PM
  3. Replies: 3
    Last Post: 26-05-2011, 12:07 PM
  4. Please Help V6 "speed sensor" keeps dying constantly?
    By igorskee in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-09-2009, 01:35 PM
  5. Please Help "T4 Wont start" :(
    By Bev@calshot in forum The Commercial Range
    Last Post: 21-02-2008, 04:53 PM
