Thread: Coolant warning light
Results 1 to 10 of 10
  1. Coolant warning light
    Aug 2011
    Surrey
    Just come home from the ya old school run, parked on an incline out side my manor and what happens the coolant light comes on " check coolant "....
    Got back in the car 5 mins later no warning.... Just to ask what coolant should I be using ...ie from Halfords....or is this stuff you can only get from Audi
  2. Re: Coolant warning light
    Apr 2012
    Aylesbury, Bucks
    If it's just slightly low (and not coming on because of the slope - park flat and let it get completely cold to check) you can top up with water (yes, it dilutes the coolant slightly, but not enough once in a while to cause a real issue - use demin water if you're a purist and of course if it keep happening check for leaks / get a rad pressure test) or any CE approved coolant from Halfords etc. Audi branded is just that, branded, and a damn sight more expensive too.
  3. Re: Coolant warning light
    Aug 2011
    Surrey
    Raf.. Cannot see any leakage.... no trace on the garage or outside where the vehicle was parked....I havnt been able to check the fluids or have the bonnet up for a few weeks...Backs been screwed...
    Probably get some coolant and some demin water and top up...after all the MOT is to morrow and the service is in 90 days so if the warning light comes on again then I'll get the garage to deal when its serviced
  4. Re: Coolant warning light
    46 Post(s)
    Audi sell G12++ which is reccommended. I posted a price on here a while ago and will go find it
  5. Re: Coolant warning light
    Apr 2012
    Aylesbury, Bucks
    Comma XStream G40 coolant is available at Halfords, is G12++ and is £25 / 5 litres. Similar deal available at Amazon, and others.
    Camskilll Tyres have it for £18, though I'm not sure what postage is there.
  6. Re: Coolant warning light
    Jun 2006
    Coolant type will be printer on header tank, G12 or G12+. Best price I found was from GFS http://www.ebay.co.uk/itm/3006096206...84.m1423.l2649
    Word of advice, never mix coolant types, even the ones that claim to be universal as they can react and cause issues. Using distilled water is supposed to be a good idea, cheapest place at present is Robert Dyas.
    Good idea to get to the bottom of why the warning is going off. Is coolant being lost or the sensor playing up?
    Hope this helps.
    Andy
  7. Re: Coolant warning light
    Aug 2011
    Surrey
    Have no I idea at the moment... Hit the check facility in the car yesterday whilst out...everything seemed ok....and it only came on when I returned from the school run....think it might be a gremlin in the system... Switched the car off for 5 mins and restarted but didnt get the coolant warning light again.... need to investigate but also need to have some stuff as have none here...
    Not to worry the local VW dealers down the road has got some in stock....so its just a 10 minute walk 4 me
  8. Re: Coolant warning light
    Sep 2011
    Lurking over a keyboard ...
    For information only useful link maybe ... http://www.blauparts.com/vw/vw_fluid...ze_fluid.shtml
    G12, G12+, G12++ can be mixed with each other for top up...
    @dealers they sell a ready mixed G12(xx) as well...
  9. Re: Coolant warning light
    Aug 2011
    Surrey
    Checked out the fluid levels before I had to collect my daughter from school... they are just above the min level so that would explain why the sensor went off this morning
    Anyway just been to the local Vw dealers....bloody nice guys... do besides the G12 ++ also got some P.S fluid...always helps to have some kocking about the place
    Just wait relax and top ups laters of early am..... need to make sure the cars ready for 10.05am MOT's tomorrow
  10. Re: Coolant warning light
    The Min/ Max marks are for when the engine is Hot. Regards Peter
    By xb25436 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-11-2010, 10:44 PM
  2. Coolant warning light, advice please.
    By airs1979 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 08-08-2010, 08:25 PM
  3. Coolant warning light
    By Scrub in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 22-06-2010, 02:46 AM
  4. coolant warning light on
    By 80ESTATE in forum 80 - 90
    Last Post: 31-03-2009, 09:06 PM
  5. Coolant Warning Light
    By wanna in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 20-03-2008, 09:32 PM
