Thread: Mk5 windscreen washer bottle...leaking
  1. Mk5 windscreen washer bottle...leaking
    X
    07 2.0 TDI (imported by me) RCD510 with MDI installed can gateway upgrade not required Jetta sport front end with projector lights
  2. Re: Mk5 windscreen washer bottle...leaking
    Mar 2011
    worcestershire
    1)Access to water bottle is from the front off side behind the where the fog light is situated. Remove the grill secured by a screw to gain access. (Looking at the front then L/H bottom corner)
    There is a rubber seal that leaks. If not then piping or a cracked bottle.
    2)Raise Front and Remove front wheel ((do not trust your car jack when working on car. Use a trolley jack (Short base trolley jacks start from approx £25)
    Access can be made by removing wheel arch cover directly behind screen wash bottle.
  1. Cracked windscreen washer bottle...
    By Trillock in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-08-2010, 10:35 AM
  2. Leaking Windscreen Washer Bottle
    By vwbolton in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-01-2010, 06:32 PM
  3. windscreen washer bottle
    By VAG in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-07-2009, 07:01 PM
  4. Please Help A4?Passat Windscreen Washer Bottle
    By mr_noir_1976 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-02-2009, 04:48 PM
  5. Please Help windscreen washer bottle
    By jacohelp in forum Polo - Derby - Lupo - Fox
    Last Post: 01-02-2009, 06:04 PM
