Thread: Rear parking sensors not working
Results 11 to 20 of 23
  1. Re: Rear parking sensors not working
    Southern County Softy
    20 Post(s)
    you could ask your dealer for the part no.
    Ebay seller link.....
    http://myworld.ebay.co.uk/goodparts32
    A4 2.5 tdi QS (mapped)
  2. Re: Rear parking sensors not working
    Mar 2012
    London, England
    Quote Originally Posted by kite View Post
    Thanks I will call them tommorro, I doubt they will give it though...
  3. Re: Rear parking sensors not working
    Oct 2009
    Birtley
    Are there any guides to taking them out? I heard that it's possible to do without taking the bumper off, is that possible?
    Audi A4 2.0TDI Quattro 177PS Black Edition (B8.5) in Brilliant Black, B&O sound system, MMI 3G+ satnav, Parking System plus, Interior LEDs, Privacy Windows
    20 Post(s)
    If it's an inner one, I removed mine without removing the bumper.
    Look for a thread started by me, A8tech posted a reply how to remove.
    follow me on twitter...kiteaudi...
  5. Re: Rear parking sensors not working
    Oct 2009
    Birtley
    VCDS says the following which I take it means the outer left?
    1 Fault Found
    01545 - Sensor for Parking Aid; Rear Left (G203)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 3
    Fault Frequency: 59
    Reset counter: 114
    Time Indication: 0
    20 Post(s)
    Could be inner or outer !!
  7. Re: Rear parking sensors not working
    #17
    Oct 2009
    Birtley
    That's a bother! I did the ticking test and all of them are ticking away. So could be a wiring problem. Do you think clearing the code with VCDS will do anything? Or will it just be the same?
  8. Re: Rear parking sensors not working
    #18
    Oct 2009
    Birtley
    I've found that it is the outer left from one of the codes from VCDS. The codes are as follows:
    Rear left parking aid sender -G203
    Centre rear left parking aid sender -G204
    Centre rear right parking aid sender -G205
    Rear right parking aid sender -G206
    20 Post(s)
    You could have a look under the bumper and see if you can reach.
  10. Re: Rear parking sensors not working
    #20
    Oct 2009
    Birtley
    ok found the post to remove sensor without removing the bumper (see below). Is there insufficient room to use this technique for the outer sensors?
    https://www.vwaudiforum.co.uk/forum/s...ghlight=bumper
  1. Parking sensors not always working
    By Little_Legs in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 06-12-2011, 08:52 PM
  2. Rear parking sensors have stopped working...
    By Saulmac in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 06-11-2011, 05:32 PM
  3. parking sensors not working
    By Bizzie in forum Octavia
    Last Post: 24-12-2010, 09:36 PM
  4. Parking sensors and rear view camera stopped working
    By Eddo1968 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 30-05-2010, 06:36 PM
  5. Please Help Sharan Parking Sensors no working
    By Burg in forum Touran - Sharan - Caravelle
    Last Post: 21-02-2010, 08:09 PM
