Thread: 2006 56 plate 105 hp 1.9 tdi jetta using oil
  1. 2006 56 plate 105 hp 1.9 tdi jetta using oil
    Jan 2011
    shetland
    hello i have been topping up the oil in my jetta every thousand miles for a couple of months now its done 105 000 how do you no if th turbo is going cant find any leaks thanks
  2. Re: 2006 56 plate 105 hp 1.9 tdi jetta using oil
    1840 Post(s)
    Anything up to a litre per 1000km is considered acceptable by VW, your problem is likely to be the turbo and disconnecting the intercooler lower pipe will probably show an accumulation of oil.
  1. Question Does my 55 plate golf tdi 105 have a DPF?
    By dave_g1007 in forum Golf MK5 - 2004 - 2009
    Last Post: 02-03-2012, 11:27 PM
  2. 2006 Jetta 1.9 TDI Warm Start Problem
    By MrXee in forum Jetta MK3 - 2005 - 2013
    Last Post: 19-08-2010, 07:44 PM
  3. Question Fitting a new engine into a 105 Tdi passat 55 plate.
    By Ashy_gtt in forum Passat - B5 Forum - 1997 -2005
    Last Post: 20-06-2009, 10:15 PM
  4. Help - Buying Passat Estate 1.9 S TDI (105) 2006 (56)
    By aperson in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 04-05-2009, 04:24 PM
  5. Oil Top Up on 57 plate 1.9Tdi Jetta
    By fusemender in forum Jetta MK3 - 2005 - 2013
    Last Post: 26-06-2008, 12:38 PM
