Thread: loss of boost, map sensor location
  1. loss of boost, map sensor location
    May 2012
    high wcombe
    Hi, first post, I have an audi a4 b6 2.5tdi. Had a little black smoke when on boost for a while, normal for 170k engine. Engine light came on EGR fault so changed that yesterday and put in a new air filter. Cleared the ecu and went for a drive, almost straight away noticed lack of boost, seams to stop boosting at about 2200 rpm and lots of black smoke. I evern have to change down gears when going uphills, never had to do that before.Put old air filter back in, no change? No engine light on but still cheched for faults and i came up with fault p0299. After reading around the web I go a new map sensor today but cannot see where it is on the car. Any help re the map sensor location and anything else would be great as off to the iow on monday for a week so dreading the drive
    Andrew
  2. Re: loss of boost, map sensor location
    Jan 2009
    Birmingham
    35 Post(s)
    i think it in the pic number 6
  3. Re: loss of boost, map sensor location
    Jan 2009
    Birmingham
    35 Post(s)
    Quote Originally Posted by arman123 View Post
    sorry wrong pic will post the correct one
  4. Re: loss of boost, map sensor location
    Jan 2009
    Birmingham
    35 Post(s)
    here you go number 6 is the map sensor
  5. Re: loss of boost, map sensor location
    May 2012
    high wcombe
    Many thanks for the picture, found the sensor and changed but found the intercooler it was on has a leak so I think its that causing the loss of boost. Any recommendations for replacement parts. Would you think its that causing my issues.
  6. Re: loss of boost, map sensor location
    1836 Post(s)
    Could be, that fault code is under boost, not over boost so a split intercooler makes sense.
  1. Please Help constant full boost!!! boost leak? MAP sensor?
    By boratdi150 in forum Bora - 1998 - 2005
    Last Post: 21-11-2017, 09:56 PM
  2. Question 2008 a3 tfsi s line map sensor / thrust sensor location..help
    By leigh76 in forum Chat - Anything with wheels
    Last Post: 22-07-2011, 09:44 PM
  3. Please Help 2008 a3 tfsi s line map sensor / thrust sensor location..help
    By leigh76 in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 22-07-2011, 07:58 PM
  4. Question Location of the IAT (G42) and Boost Sensor (G31) Sensor
    By Poenie in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 02-04-2010, 12:17 AM
  5. MAP Sensor location?
    By MikiebV6 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 29-12-2009, 05:41 PM
