Thread: Tailgate hinge bolt snapped
Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
  1. Re: Tailgate hinge bolt snapped
    #21
    Dec 2016
    Australia
    Quote Originally Posted by polymer8 View Post
    Thanks for posting - very informative. I'm halfway thru the repair - just need to get myself a new T30 TORX - first one snapped!
    I just finished the job. All went well, but a few thoughts to consider.
    - It is a M6 x 16mm High Tensile bolt that is required. VW parts showed no interest supplying my any HT bolts, so I purchased from a specialist fasterner place. Make sure you get HT and not any old tat from a general hardware.
    - Removing the hinge nuts (car chassis side) takes care. I used a magnetised 13mm socket to ensure I did not drop the nut when it is removed. To do so would mean a lost nut somewhere burried deep with the char chassis.
    - A bit of heat on the sheared remains of the bolt and a wiggle with a pair of pliers got is clear.
    - Putting it all back together only took a fraction of the time compared to pulling it all apart.
    Overall I can't believe that VW thought a couple of M6 machine screws would be sufficient for such a high load attachment that is subjected to repeated stresses and shocks.
  2. Re: Tailgate hinge bolt snapped
    #22
    Sep 2016
    Australia
    I had no problems getting VW to order me the screws (didn't even need to pre-pay) - the only thing I would say about using non-genuine screws is the VW parts have a thread lock compound pre-applied (not that it stopped my original ones from unwinding). So use some Loctite when fitting new ones.
    The pockets where the hinges go seem to be closed so you shouldn't lose a nut - I dropped mine many times but never had one lost forever.
    Have to agree that it seems fairly unimpressive engineering only relying on only a single screw per side - but the problem seems to be that they unwind themselves and then bend/snap. Non HT screws would almost certainly fail in tension without needing to loosen off first
    What is impressive is that the motors with minimal leverage can swing that big heavy tailgate so effortlessly.
  3. Angry Re: Tailgate hinge bolt snapped
    #23
    Dec 2016
    Australia
    Quote Originally Posted by CaseySP View Post
    I'm revisiting this thread as the other bolt has now sheared. Interestingly (for me at least) this one was not loose, it was tightly fastened but it still sheared. Confirms to me that the design is not up to the job. Now contemplating if I can get the screw stud out of the hinge without all the dismantling.
  4. Re: Tailgate hinge bolt snapped
    #24
    Sep 2016
    Australia
    Bummer. I sold the earlier Passat last year and bought a new 206TSi R-Line The newer model has done away with the motors bolted onto the hinges for a design that uses motorised struts (linear actuators). Much more civilised, rather then closing with a slam, the boot is carefully and quietly squeezed close.
  5. Re: Tailgate hinge bolt snapped
    #25
    Dec 2016
    Australia
    I'm glad they sorted that out. I did manage to replace the bolt and have a box of spare HT bolts - expecting this to be a regular thing!
  1. Question Audi 80 Avant Tailgate hinge wiring ???
    By Timk in forum 80 - 90
    Last Post: 07-05-2012, 10:07 AM
  2. Rear Washer Pipework - tailgate hinge
    By NickPicks in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 27-02-2012, 05:16 PM
  3. arrow in tailgate hinge
    By asrpaint in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 29-01-2011, 04:17 PM
  4. Snapped glovebox hinge
    By JON4C in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 24-03-2010, 10:58 PM
  5. Drop link bolt snapped in roll bar
    By rob160 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 11-06-2008, 01:16 AM
