Thread: A6 C7 VCDS Tricks
Page 83 of 87 FirstFirst ... 33738182838485 ... LastLast
Results 821 to 830 of 861
  1. Re: A6 C7 VCDS Tricks
    May 2009
    Newcastle-under-Lyme Staffordshire
    41 Post(s)
    Quote Originally Posted by johnro79 View Post
    hi there
    is there a code for turning the "break pads" warning light off?
    it's a major fail with the new MOT coming this year.
    if it'll go on the night before, it'll be handy to be able to turn it off before doing the MOT
    thanks for your time
    Even if this was possible (which I don't think it is), it would be irresponsible and potentially dangerous to do. I'd be surprised if you find anyone willing to try. Imagine the liability implications if someone bypassed the warning and the car was subsequently involved in an accident that killed a person, because the brakes were dangerously worn. Anyone previously tampering with the brake safety warning would likely be held equally culpable.
    Do the right thing and replace the pads if they are near the end of their life.
    Cheers!
    MF.
    Now: E 53 AMG 4MATIC
  2. Re: A6 C7 VCDS Tricks
    Jan 2017
    TLS, France
    9 Post(s)
    hi there
    There isn't a code and nothing that a new set of pads won't fix.
  3. Re: A6 C7 VCDS Tricks
    Apr 2016
    London/UK
    14 Post(s)
    somehow my lights are coming on when they are 70-75% gone and the squeaking during breaking when they're 80-85%
    still a lot of life in them left though
    PS: i change both front and rear twice a year.i am doing about 65-70k miles/year with calm driving....
  4. Re: A6 C7 VCDS Tricks
    Mar 2014
    Edinburgh
    228 Post(s)
    Thatís quite a lot but the A6 is a 2 ton barge so things like brakes pads will wear quickly and most being automatic you are more likely to be riding the brakes in slow traffic.
  5. Re: A6 C7 VCDS Tricks
    Jan 2017
    TLS, France
    9 Post(s)
    Considering your mileage then twice a year for a pad change seems about on par.
  6. Re: A6 C7 VCDS Tricks
    Feb 2013
    Gloucester
    53 Post(s)
    If your pads are squealing, take them to Any garage and they can stop it.
    If your warming light is on that early into their life, they have been fitted by an ape or you have a problem. Again, a garage can sort it if you canít.
    There is a way to bypass the warning light but as itís a safety feature it would be insane to do so.
    Sent from my iPhone using Tapatalk Pro
    Audi A7, S-line, 313 PS BiTDI Tiptronic, Daytona Grey, heated front and rear seats, Audi connect, quad zone climate control, ski chute and bag, Rear tints, 75 Litre fuel tank, All LED headlights, Night vision assistant, Rear view camera with corner view, Navigation plus, MMI touch, Heads up display, Adaptive Cruise control, Blind spot monitoring and active lane assist. Audi A5 (wifes) My Kit car blog - http://mitchsgbszero.blogspot.co.uk
  7. Re: A6 C7 VCDS Tricks
    Jan 2013
    Scotland
    11 Post(s)
    is there any coding to have c7.5 tail lights on with DRLs. I notice there is coding for preface-lift, but not face lift?
    Audi A6 3.0 BiTDI Black Edition
  8. Re: A6 C7 VCDS Tricks
    Apr 2011
    basingstoke,england
    11 Post(s)
    Quote Originally Posted by gdallas View Post
    I bet the pre fl method will work with the fl cars, have you tried it?
    2016 A6 Avant 2.0 tdi Quattro Black Edition
    2013 A6 Avant 2.0 tdi Black Edition ​gone
    2010 A6 Avant 2.0 TDI Le Mans. gone.
  9. Re: A6 C7 VCDS Tricks
    Jan 2013
    Scotland
    11 Post(s)
    Quote Originally Posted by SMILEMAN View Post
    Ye I did actually. Probably should have said, sorry. I clicked on Byte 2, then enabled bit 7 (I think it was) but I got something like en error 31 rejection error or similar. out of range i think it also said. perhaps i was doing it wrong.
  10. Re: A6 C7 VCDS Tricks
    Jan 2018
    Mexborough
    22 Post(s)
    Yes done it on mine
  1. Audi A4 B8 - VAG.com Tricks
    By 73kingstonroad in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 11-01-2019, 11:47 PM
  2. mark 5 tips and tricks
    By m24man786 in forum Golf MK5 - 2004 - 2009
    Last Post: 17-03-2010, 09:58 AM
  3. Audi A6 Tricks ??????????????
    By slice636 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 28-10-2009, 12:27 PM
  4. Question vag com tricks?
    By andymartin045 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-09-2009, 07:43 PM
  5. tips and tricks for golf mk5's
    By Ben in forum Golf MK5 - 2004 - 2009
    Last Post: 17-08-2008, 09:25 PM
