Thread: A6 C7 VCDS Tricks
Page 51 of 90 FirstFirst ... 41495051525361 ... LastLast
Results 501 to 510 of 897
  1. Re: A6 C7 VCDS Tricks
    Nov 2012
    Somerset UK
    Quote Originally Posted by damtom85 View Post
    in very hot weather in Europe
    Anyone remember these in the UK? I can't remember in the last decade it getting up into the 80's often...must be global warming?
    I appreciate that in a car everything's magnified inc. the temp, but still better than living in New Mexico where your windscreen would shatter due to the high temps and hailstones bigger than golf balls would make a completely ruin car bodywork
  2. Re: A6 C7 VCDS Tricks
    Dec 2015
    Legnica Poland
    I'm new on this forum.
    I have a question about MMI 3G Plus Start Up Screen.
    I have seen in Audi Q5 at Start Up Screen custom picture.
    Does anyone know how to do this in Audi A6 C7?
    Thank for your help and sorry form my English...
    Grettings
  3. Re: A6 C7 VCDS Tricks
    46 Post(s)
    Not with VCDS you can't.
  4. Re: A6 C7 VCDS Tricks
    Dec 2015
    Legnica Poland
    Are there any other opportunities to do that?
  5. Re: A6 C7 VCDS Tricks
    Feb 2013
    Uk
    37 Post(s)
    BREAK PAD WEAR WARNING ACTIVE
    I was having a look around on VCDS today noticed "BREAK PAD WEAR WARNING ACTVIVE" Bit 0 was unchecked, see image.
    anyone enabled it ? ( I thought this would of been already enabled ?)
  6. Re: A6 C7 VCDS Tricks
    46 Post(s)
    It is enabled. I think it's an error in the software as this shows on all models even though it's enabled.
  7. Re: A6 C7 VCDS Tricks
    Feb 2013
    Uk
    37 Post(s)
    Thx chris
  8. Re: A6 C7 VCDS Tricks
    Sep 2011
    Crawley, West Sussex
    Hi guys, I was wondering if anyone can give me some guidance please with regards to :- Ambient lighting footwell lights ?
    With the kind help of Mustard yesterday, we managed to turn on both my front & rear footwell lights using step 26 Vcds tricks below, however we did not manage to get into hidden menu as in step 5 as I did not print this out at the time and only realised it last it night.
    My footwell are now working with lights on , however they are only very dimly lit, and go to full brightness when opening the doors. So I am assuming that I need to go into the hidden menu as per step 5 to be able to adjust brightness from MMI screen ...is this correct and will I be able to control these from MMI screen ?
    Please can anyone tell me ...do I need to re visit Mustard & connect VDCS again to be able to go into Hidden Menu and set this up again as per second part of instructions on step 26 ? a
    Any advice would be most appreciated and thanks in advance
    26. Activation of footwell lighting for vehicles without Lighting Pack / Ambient Lighting
    This allows you to use the MMI to set the footwell lighting level while driving. Tested on cars with MMI 3G+ (Tech pack).
    [Select]
    [09-Cent. Elect]
    [Coding - 07]
    [Long Coding Helper]
    Click on byte 16 and enable bit 6
    [Do It!]
    Enter the Hidden Menu as in step 5 above.
    Select Car
    Select Cardevicelist
    Check "Interior Light"
    Return
    Select Carmenuoperation
    Set "Interior Light" from 0 to 5
    Return
    Press CAR to exit the hidden menu
    Reboot the MMI
    Thanks to Hellodave for finding this.
    This is Step 5 instructions :-
    5. Hidden menu
    Enable access to the green engineering menu in the MMI
    [Select]
    [5F - Information Electr.]
    [Adaptation - 10]
    Select Channel 6 and Read
    change the value from 0 to 1 then Test then Save
    Reboot the MMI (Press MENU, central MMI knob and top right softkey)
    To get to the Hidden Menu, press and hold the CAR and MENU buttons for a few seconds. You may have to have a few attempts - if you don't press them at the exact same moment either CAR or MENU activates. You know if you have done it right because the red LEDs in the buttons do not illuminate.
    WARNING!!!! BE CAREFUL!!! Do not mess with settings in the Hidden Menu unless you know what you are doing. On earlier MMI versions, people managed to activate the bootloader menu and fried their MMI. Use at your own risk. If in doubt, leave well alone!
  9. Re: A6 C7 VCDS Tricks
    46 Post(s)
    Yes you need to enable the menu for the MMI, you will then get this option shown below
    They will then be enabled anytime your headlights are active and the adjustment of brightness will be memorised.
    2 1 0
  10. Re: A6 C7 VCDS Tricks
    Mar 2008
    11 Post(s)
    If you're trying to get the hidden menu on the facelift A6 (2015+) it's not going to work. Unless things have changed in the last couple of weeks, it's not possible to enable the menu on the FL as of yet
    Mine currently behaves the same as yours having enabled background lighting
    Audi A7 Black Edition 3.0 TDI (272) 2015 (FL)
  1. Audi A4 B8 - VAG.com Tricks
    By 73kingstonroad in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 08-03-2021, 05:34 PM
  2. mark 5 tips and tricks
    By m24man786 in forum Golf MK5 - 2004 - 2009
    Last Post: 17-03-2010, 09:58 AM
  3. Audi A6 Tricks ??????????????
    By slice636 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 28-10-2009, 12:27 PM
  4. Question vag com tricks?
    By andymartin045 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-09-2009, 07:43 PM
  5. tips and tricks for golf mk5's
    By Ben in forum Golf MK5 - 2004 - 2009
    Last Post: 17-08-2008, 09:25 PM
