Thread: A6 C7 VCDS Tricks
Page 42 of 90 FirstFirst ... 32404142434452 ... LastLast
Results 411 to 420 of 897
  1. Re: A6 C7 VCDS Tricks
    Apr 2014
    Tamworth, Staffs, UK
    10 Post(s)
    Hi Folks,
    Picked up my new facelift Black Edition earlier in the week and have been out with the laptop and VCDS. The one I don't seem to be able to get working is the one to automatically apply the handbrand when shifting into P (Automatic) - any ideas? The adaptation has been accepted and is showing as activated, but nothing happens.
    Any ideas?
  2. Re: A6 C7 VCDS Tricks
    Mar 2014
    Edinburgh
    235 Post(s)
    My fl does this out the factory without any coding.
    You need to take the seatbelt off for it to apply handbrake fully
  3. Re: A6 C7 VCDS Tricks
    Apr 2014
    10 Post(s)
    Quote Originally Posted by A6S View Post
    Doesn't work on mine...
    So, handbrake does not apply even though I've set the correct values; does not apply when the engine has been turned off, nor does the engine turn off when you open the drivers side door.
    My previous BE did this, so I know it's possible, just not sure why it's not
  4. Re: A6 C7 VCDS Tricks
    May 2013
    Wisbech
    8 Post(s)
    What type of transmission you have?
  5. Re: A6 C7 VCDS Tricks
    Apr 2014
    10 Post(s)
    S-Tronic 2.0tdi
  6. Re: A6 C7 VCDS Tricks
    May 2013
    Wisbech
    8 Post(s)
    I know tiptronic won't work with that but stronic should work with this coding perfectly fine
  7. Re: A6 C7 VCDS Tricks
    Apr 2014
    10 Post(s)
    It worked on my multitronic this has just replaced so not sure if it's a different coding for a new model / engine / Ecu combination.
  8. Re: A6 C7 VCDS Tricks
    Feb 2013
    Gloucester
    57 Post(s)
    Quote Originally Posted by damtom85 View Post
    It works with my tiptronic
  9. Re: A6 C7 VCDS Tricks
    May 2013
    Wisbech
    8 Post(s)
    I have tiptronic in my a8 12 reg and it doesn't work also I have seen comments in here that it doesn't work with tiptronic. So now I'm getting confused
  10. Re: A6 C7 VCDS Tricks
    Feb 2013
    Finland
    13 Post(s)
    Disable/memorize/invert Start & Stop:
    - module 09-Cent. Elec.
    - enter Security Code (20113)
    - Adaptation on Channel 34:
    subtract 4 to the value --> Start&Stop always disabled
    add 32 to the value --> memorize last status (the Start & Stop status at engine startup will be the one at last engine shutdown)
    - test & save
    In addition of these values, if you add 64 to the value, the Start & Stop button light will be reversed: off if Start & Stop is disabled, and on if Start & Stop is enabled.
    Found from several forums, original maybe audizine, also audipassion (FR) and a5oc. Tested "add 32" on my 2012 3.0 TDI car and it works. Original was 20.
    A6 4G 2012 Avant S-Tronic 3.0 TDI quattro 180 kW, Dakota Grey, adaptive air suspension, Comfort package & leather seats, all electric seats/mirrors/steering wheel/trunk lid, light package, aux heater, towbar
  1. Audi A4 B8 - VAG.com Tricks
    By 73kingstonroad in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 08-03-2021, 05:34 PM
  2. mark 5 tips and tricks
    By m24man786 in forum Golf MK5 - 2004 - 2009
    Last Post: 17-03-2010, 09:58 AM
  3. Audi A6 Tricks ??????????????
    By slice636 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 28-10-2009, 12:27 PM
  4. Question vag com tricks?
    By andymartin045 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-09-2009, 07:43 PM
  5. tips and tricks for golf mk5's
    By Ben in forum Golf MK5 - 2004 - 2009
    Last Post: 17-08-2008, 09:25 PM
