Thread: A6 C7 VCDS Tricks
Page 11 of 90 FirstFirst ... 9101112132161 ... LastLast
Results 101 to 110 of 897
  1. Re: A6 C7 VCDS Tricks
    Feb 2013
    Finland
    13 Post(s)
    09 - central electrics, first module BCM
    Byte 3
    bit 0
    daytime running lights adjustable via MMI
    enables DRL on/off setting in MMI. Our Audi importer have hidden the menu and set DRL permanently ON (very wise they did that for our weather conditions, esp. tail lights). In same instances it would be nice to have ability to completely switch lights off, so this enables MMI menu item, in case you don't have it.
    Byte 4
    Bit 6 enables tourist mode setting in MMI (driving on left (= wrong) or right). Headlights will be dipped a bit, usefull when driving in a convoy because the lights tend to blink the car mirror in front on a hilly roads.
    Bytheway, german version "DRV" of VCDS at ross-tech.de has much more coding texts and adaptation explanations than in imperial version.
  2. Re: A6 C7 VCDS Tricks
    46 Post(s)
    Just enabled a few things on a 2014 (Nov 2013 build) SE 2.0 TDI (Engine Code - CGLC) with Colour DIS and HDD.
    Chirp on lock
    Needle sweep
    Boost gauge (working!) /lap timer/oil temp
    Battery meter
    Cornering fogs
    VIM
    Already had mirror dip on reverse as it has elec memory seats anyway.
  3. Re: A6 C7 VCDS Tricks
    Aug 2007
    Hook Hampshire
    21 Post(s)
    Chris, How did you get the oil temperature and battery meter to work. Regards
    Audi A7 3.0TDi 2011 160k miles, engine code CLAB 204bhp 2WD
  4. Re: A6 C7 VCDS Tricks
    46 Post(s)
    Look at 1 and 2 in post #1 then go into the menu button on the steering wheel (one beside the left hand side scroll wheel) then go into Lap Timer.
    Will take some pics tomorrow, think some early clusters weren't compatible.
    Address 17: Instruments (J285) Labels: 4H0-920-xxx-17.clb
    Part No SW: 4G8 920 984 H HW: 4G8 920 984 H
    Component: TDieGb H58 0621
    Revision: 29460233 Serial number: 658051113596017
    Coding: 33AF080003412600010000
    Shop #: WSC 02391 785 00200
    ASAM Dataset: EV_RBD4K 004048
    ROD: EV_RBD4K.rod
    VCID: 3B714F22B2A58CC68E5-806E
  5. Re: A6 C7 VCDS Tricks
    46 Post(s)
    I'll get you some pics soon but I found another feature you automatic owners might enjoy.
    53 - Parking Brake
    16 - Security Access
    Code shown to me was 78713
    10 - Adaption
    "Shift P to EPB"
    Set to Activated
    This will auto-apply the handbrake when the shifter has moved to P.
  6. Re: A6 C7 VCDS Tricks
    46 Post(s)
    Quote Originally Posted by shabazmo View Post
    Pics as promised, boost is little as I had it in R on the driveway.
    You can see the little bars appearing beside the rev counter.
  7. Re: A6 C7 VCDS Tricks
    Southern County Softy
    20 Post(s)
    Put your belt on.....
    Sent from my GT-I9505 using Tapatalk
    A4 2.5 tdi QS (mapped)
  8. Re: A6 C7 VCDS Tricks
    46 Post(s)
    Quote Originally Posted by kite View Post
    Due to the unique way the multitronic works, I wasn't actually moving
  9. Re: A6 C7 VCDS Tricks
    Feb 2013
    Gloucester
    57 Post(s)
    Done both the lap timer and the auto parking brake. There is no temperature shown for the oil though, as with your pics above its just blank - is there a way to fix this? I drove until my engine was at normal operating temperature. Auto parking brake is awesome though!
  10. Re: A6 C7 VCDS Tricks
    46 Post(s)
    Oil temp works fine on this cluster, car was stone cold when I took the pic.
  1. Audi A4 B8 - VAG.com Tricks
    By 73kingstonroad in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 08-03-2021, 05:34 PM
  2. mark 5 tips and tricks
    By m24man786 in forum Golf MK5 - 2004 - 2009
    Last Post: 17-03-2010, 09:58 AM
  3. Audi A6 Tricks ??????????????
    By slice636 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 28-10-2009, 12:27 PM
  4. Question vag com tricks?
    By andymartin045 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-09-2009, 07:43 PM
  5. tips and tricks for golf mk5's
    By Ben in forum Golf MK5 - 2004 - 2009
    Last Post: 17-08-2008, 09:25 PM
