Thread: MK5 Golf interior light
  1. MK5 Golf interior light
    Aug 2007
    HI
    I have just bought a 2004 1.6 FSi, while reading the owners manual, it stated the interior light should come on when I unlocked the door if the rocker switch is set in middle posistion It doesnt come on and the rocker switch is set in the middle.
    Does anybody know if this is a common fault, and does it require a new switch?
    I have checked the fuse's which are all fine.
    Thanks in advance for any help on this.
  2. Re: MK5 Golf interior light
    Coventry
    Welcome, the bulb works on the other settings of the switch? When you unlock the car do the head lights come on? Mine do but only in the dark. This is to do with the light sensor on the interior mirror. Your interior light may not come on in daylight, why would you need it in the day? Investigate this. If its still not working, it may well be down to a convenience setting, depending on the computer / mfd thats fitted to the car you may be able to enable it yourself, if not it can probably be done with vagcom.
  3. Re: MK5 Golf interior light
    Jul 2007
    Sorry to change the topic slightly, but how do you remove the casing for the light? I need to change one of the bulbs!
  4. Re: MK5 Golf interior light
    Aug 2007
    The head lights dont come on. Maybe I need to take it to the main dealer?
  5. Re: MK5 Golf interior light
    Coventry
    is this when unlokcing with the remote.
    if so, the headlights are in the convienience settings and you should be able to have the feature enabled. this may also activate the interior light as well.
  6. Re: MK5 Golf interior light
    Aug 2007
    Yes it is when unlocking with the remote, although the interior light doesnt come on when opening the door.
    Is this an easy fix, can I do it myself?
  1. Interior light!
    By earlybayscampi in forum 80 - 90
    Last Post: 23-02-2007, 11:54 PM
  2. Interior light
    By Rogg in forum Passat - Archive Topics
    Last Post: 28-12-2006, 06:54 PM
  3. Interior light
    By Gaz the Cab in forum Passat - Archive Topics
    Last Post: 03-10-2006, 08:36 PM
  4. Audi 80 - Interior light
    By Mr Grilkes in forum 80 - 90
    Last Post: 22-11-2005, 06:22 PM
  5. Interior light
    By msond in forum 80 - 90
    Last Post: 25-02-2005, 04:04 PM
