Thread: Ciggy lighter not working
  1. Ciggy lighter not working
    Sep 2009
    england
    Hi all,
    Can anyone tell me please, where the fuse is for the ciggy lighter in the boot? All my fuses in the dash end fuse box are OK so I guess it is somwhere else.
    Regards Dave
  2. Re: Ciggy lighter not working
    Dec 2007
    wigan
    it is behind the drivers side lower dash panel
    2 hex screw's in d/s fuse panel
    1 right of steering wheel near the pocket
    1 left side of steering wheel near pocket
    remove lower panel by pulling it not forgetting to disconnect the headlight switch and headlight level and cluster dimmer switches
    you will see on the right side fuses and relay's thats where they are
    refit is opposite of removal except there are two guides that the rear underside of the panel need to slot into you will see them one left side nr clutch ( metal ) and one right side nr accelerator pedal ( white plastic )
    these need aligning or it will sag at rear..!!
    hope that help's
    Passat Tdi 130 Sport
    Audi RS4 alloys polished alloy fronts
    no mod's
  3. Re: Ciggy lighter not working
    Oct 2007
    The diagnostic socket needs releasing from the panel to remove it from the car, it is screwed from the inside of the panel.
  4. Re: Ciggy lighter not working
    Sep 2009
    england
    Brill. Many thhanks!
    Went straight to it, after taking the other two screws out from under the fuse box cover. I would never have found that!
    5 minutes to replace the fuse--- 25 minutes to put it all back together again.
    Why not put them all in the fuse box?
    I guess the 40amp fuse in the same place is the glow plugs supply?
    Regards Dave
  1. Ciggy lighter socket.
    By Jason.S in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 02-08-2011, 03:24 PM
  2. Please Help cigerrete lighter not working
    By bigbadsexy in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 10-03-2011, 07:15 PM
  3. Ciggy Lighter
    By bloodygoodbloke in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 03-11-2009, 02:23 PM
  4. Cigarette lighter not working...
    By SB83 in forum Golf MK5 - 2004 - 2009
    Last Post: 07-01-2009, 11:34 PM
  5. Cigarette lighter not working - Engine & Oil temp gauges not working.
    By Shagger7 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-02-2008, 12:10 PM
