Thread: Please help before my A6 Quattro bankrupts me...
Results 1 to 10 of 11
  1. Post Please help before my A6 Quattro bankrupts me...
    Apr 2012
    London, UK
    I hope someone can help me with this, here goes...
    My car is an A6 2.5TDI Quattro Avant 02 plate - a couple of months ago I started getting a couple of intermittent problems; firstly the engine would run fast (1,200 rpm on tickover as opposed to the usual 800 rpm) and at the same time the car would change gear at the wrong time - it would drop down a gear when it shouldn't and/or would not change up when it should until hitting over 4,500 rpm. Secondly - and I don't know if this is related to the first problem - the ESP light would come on and stay on until I restarted the car. Again, I stress that both problems were intermittent.
    Anyway, two weeks ago I lost all transmission and the gearbox went into "PRNDS" failsafe mode. I had the car taken to a transmission specialist and I had to have the whole gearbox rebuilt for two grand. The guy showed me all the damaged cogs, clutch and hydraulic parts that had come out, it was buggered. He had also checked the ECU which was clear and all was now good, or so I thought.
    I picked the car up Friday; on Saturday - I think you can guess where this is going - the same problem came straight back; the car started running too fast during a drive and was changing gear when it shouldn't. Sunday and today, the car runs fine.
    Given that the gearbox is now (internally) all new, and the ECU is producing no faults, I can only surmize that the EMS is in error in both causing the engine to run too fast which is having the knock-on effect of incorrect signals being sent to the gearbox. The problem is that I'm not getting any EMS fault registering on the dashboard and nor is there any showing when the RAC guy (who I called out Saturday) ran his diags.
    Can anyone help? I've spent a ton of cash on this already and it seems that I've had the effect of the problem fixed, but not the cause... Help!
    (PS: I've been reading all about various problems people have had with the Multitronic gearbox, but this being the Quattro I'm right in saying this has the Tiptronic box, right?)
    Southern County Softy
    20 Post(s)
    That's right, you don't have multitronic. A vagcom scan would be the first thing to try, see if any faults are logged.
    Look in the vagcom section for a member in your area goal a scan.
    Sent from my GT-I9100 using Tapatalk 2
    A4 2.5 tdi QS (mapped)
  3. Re: Please help before my A6 Quattro bankrupts me...
    Apr 2012
    London, UK
    Thanks Kite,
    Please excuse my complete ignorance, what exactly is a Vagcom scan?
    20 Post(s)
    Vagcom= diagnostic software.
    Where in the UK are you?
    20 Post(s)
    I see your in London.
    Chris( adamss24) is in north London and is good around a V6. Try sending him a private message
  6. Re: Please help before my A6 Quattro bankrupts me...
    Apr 2012
    London, UK
    Thank you very much for your help mate but I'm actually about 30 miles west of London in south Bucks, I'll take a look in the section you mentioned, hopefully there's someone not too far away, thanks again mate.
    20 Post(s)
    I'm in Bracknell and have VCDS if that's any nearer for you.
  8. Re: Please help before my A6 Quattro bankrupts me...
    Mar 2008
    High Wycombe
    And I'm in High Wycombe if it's any closer. I can do you a vagcom scan tomorrow (laptop's at home today).
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  9. Re: Please help before my A6 Quattro bankrupts me...
    Apr 2012
    London, UK
    Nick, thank you so much - that would be great. I've just tried sending you a PM but my post count is not high enough to do so, any chance you could send me one with your number on? Thanks again mate.
    And thank you Kite for your equally kind offer, what a pleasant bunch on here.
  10. Re: Please help before my A6 Quattro bankrupts me...
    Jul 2011
    Cheddington
    The coolant temp sensor makes the car idle at 1200rpm+ if it's faulty. Could be worth replacing this as it's cheap (under £10) and 5mins to DIY.
  1. Question Quattro owners - 3.0 TDI Quattro - tyre scrubbing on half to full lock - any ideas?
    By Thon in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 07-03-2012, 02:20 PM
  2. Moving from b6 3.0V6 quattro to B7 2.0TFSI quattro
    By warp_speed in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 12-05-2011, 09:07 AM
  3. ADVICE PLEASE = 2.0 TDI(170) quattro or 2.0 TFSI quattro??
    By missscotia in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 15-01-2010, 11:15 PM
  4. Engine out of '91 200 20V Turbo Quattro into '90 Coupe Quattro
    By 90 Coupe Q in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 01-11-2009, 11:38 AM
  5. Question I have to compromise: 1.9 Quattro or 2.5 non-Quattro - What would you choose?
    By toff in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 17-08-2009, 07:59 PM
