Thread: Golf mk 5 reverse light and fog light swap for lhd rules
  1. Golf mk 5 reverse light and fog light swap for lhd rules
    Aug 2011
    london
    Living abroad with my rhd vw, having swapped my rear fog and reverse light inner lens on my standard golf mk5 sdi to conform lhd with driving regs as it only has one of each nothing has changed, when the fog is switched on the reverse light illuminates now and when the reverse is engaged the fog light does , help, does the vdcs need to to entered and if so does anyone know how and what needs to be done to swap the switch functions
  2. Re: Golf mk 5 reverse light and fog light swap for lhd rules
    Norfolk
    Yes, there is an option in VCDS to swap them over.
  3. Re: Golf mk 5 reverse light and fog light swap for lhd rules
    May 2010
    Devon England
    Go in to the CECM and then long code helper and its in there, depends what CECM you have aswell mate as to the byte you need to change
  4. Re: Golf mk 5 reverse light and fog light swap for lhd rules
    Aug 2011
    london
    thank you very much for that, but as im only a greenhorn at all this electronic stuff i am going to have to take it to a vw dealer in belgium to get it done,
    Would you have any specific pointers i can give to them so as it doesnt appear to them that i am completely and they are clear about what i want done and so as they dont try to fleece me which im hopeful they wouldnt cynical old me
  5. Re: Golf mk 5 reverse light and fog light swap for lhd rules
    Aug 2011
    london
    thanks for the info
  6. Re: Golf mk 5 reverse light and fog light swap for lhd rules
    May 2010
    Devon England
    this is what mine is like
    Hop this helps mate
  7. Re: Golf mk 5 reverse light and fog light swap for lhd rules
    Apr 2012
    UK & Germany
    Hi Newbie here,
    Like others in the thread I will soon be moving to Germany with RHD cars (Golf MkV and Octavia II when it is finally built). I have paid the dealer to swap previously but I am considering buying VCDS and cable as both cars require this procedure (although having looked at the Briskoda forums this may be more difficult on the Octy than the Golf).
    A quick question if I may...
    On the MkV you are required to swap fog / reverse inners and then reprogramme via VCDS. If you use the activate both fogs setting as per Phil's photos do you not just activate the reverse light when you switch the fogs on?
    Is there not a requirement to change the country codes so the car is set up as LHD?
  1. Question golf front right fog light defective
    By smoggyrich in forum Golf MK5 - 2004 - 2009
    Last Post: 16-01-2012, 07:27 PM
  2. Rear fog light / reverse light fault (golf 5)
    By 85turbo in forum VCDS - General Questions
    Last Post: 03-09-2010, 11:30 PM
  3. Only have one reverse and one rear fog light
    By Akash in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 25-07-2008, 07:08 PM
  4. LHD fog light
    By scootermap in forum Audi A4 - Archive Topics
    Last Post: 20-11-2007, 05:38 PM
  5. New Golf V - reverse / fog light
    By shelven in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 12-08-2007, 11:05 PM
