Thread: What to look for when buying an Audi A6
  1. What to look for when buying an Audi A6
    Dec 2007
    Hi Folks,
    I am going to look at a 2004 Audi A6 1.9 TDI 130 SE Multitronic Diesel Avant this evening.
    Any of you good people on this site have any tips to look for when buying a car of this age please?
    Cheers,
    JJT
    Last edited by Guest 2; 07-04-2012 at 09:11 AM. Reason: Moved from 'Forum Improvement Suggestions' :S
  2. Re: What to look for when buying an Audi A6
    Dec 2007
    Someone must have opinion on buying one of these vehicles please?
    Thanks in advance
    JJT
  3. Re: What to look for when buying an Audi A6
    46 Post(s)
    Hi there,
    As you know its Easter weekend so there won't be many people around as there normally is but I'm sure it won't be too long before someone comes along.
    Have a quick look through the previous threads on the C5 and see if there are any recurring questions.
  4. Re: What to look for when buying an Audi A6
    Jun 2009
    Bexleyheath, England
    I am sure most users will say, not the "multichronic" gearbox !!! go for a tiptronic or manual instead.
    George
    1998 A6 Avant 2.5TDI AFB
    RETIRED @ 185K miles,
    2006 A6 Avant 3.0TDI BMK S Line Quattro retired due to RTC
    2009 S4 B8 Avant Stage 2 + DP EPL & TCU, big list of mods
  5. Re: What to look for when buying an Audi A6
    Dec 2007
    Joe,
    Thanks for replying - the advert mentions 'Multitronic' in the title but 'tiptronic' in the body of the text. It's an auto so which is likely to have? Or are they both the same?
    Any comments gratefully received please?
    Cheers,
    JJT
  6. Re: What to look for when buying an Audi A6
    Ayrshire, Scotland
    18 Post(s)
    Tiptronic is on quattro, multitronic on 2wd,
    check all electrics work, Windows central locking, look under the battery tray, if pools of water there may be damage to convenience module, check cv boots aren't split, on auto boxes make sure gear change is smooth and fully operational.
    Regards
    Andy
    2001 Audi A4 Saloon 2.0
    2000 Audi Allroad 2.5TDI V6 quattro
    Fully licenced Ross-Tech VCDS Interface
    Air Suspension Compressor Repair Kits: www.bagpipingandy.com
  7. Re: What to look for when buying an Audi A6
    Nov 2011
    Duns Scotland
    11 Post(s)
    If you are detrermined to get an Audi (or VW), seriously think of investing in the Ross-Tech VCDS system. (USB2 cable + smarts that connects your laptop or pc to the multi-pin input port in the car + the VCDS software). With this you can check for any faults reported by the VAG system on the car. Checking for faults is a SAFE function - ie you cannot do any harm and it takes about 5mins. The output will be a full systems check on the health of the car. If you ar buying from a dealer ask if they have the equivalent and if they will show you the printed results.
    As in other posts, you also need to do the various visual checks.
    Best of luck.
  1. Question Buying Audi A3 8L
    By matthew1kings in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 31-08-2010, 11:40 AM
  2. Question Buying a used Audi A4 - help
    By audia4tdv in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 22-07-2009, 09:53 AM
  3. buying an audi
    By mark_dixon2105 in forum Audi A3 - Archive Topics
    Last Post: 25-03-2008, 02:13 PM
  4. Buying Audi s3
    By marcoaten16v in forum Audi A3 - Archive Topics
    Last Post: 25-04-2007, 05:43 PM
  5. Buying an Audi 80
    By Captain Answer in forum 80 - 90
    Last Post: 20-04-2007, 05:58 PM
