Thread: Allroad Air Suspension Compressor strip & repair
Page 2 of 47 FirstFirst 123412 ... LastLast
Results 11 to 20 of 461
  1. Post Re: Allroad Air Suspension Compressor strip & repair
    #11
    Sep 2009
    A406
    This is VW oem kit with part number 100 698 010A
    Contains:
    - Wabco compressor head with integrated dryer
    -Teflon Piston Ring
    -Head bolts
    -Rubber o ring Seals
    -Cable clips
    V6 Tdi Power!
  2. Re: Allroad Air Suspension Compressor strip & repair
    #12
    Ayrshire, Scotland
    18 Post(s)
    Quote Originally Posted by All-rod View Post
    This is Audi oem kit with part number 100 698 010A
    Contains:
    -Teflon Piston Ring
    -Head bolts
    -Cable clips
    Got it on ebay, I saw this kit pop up second time now, but different sellers.
    Affraid that kit is for a vw touareg, and wrongly advertised for the allroad. the drier unit is different and has a outlet to inflate wheels, however the piston ring and seal should be the same and are what i am offering and should fit.
    How much was it?
    Andy
    2001 Audi A4 Saloon 2.0
    2000 Audi Allroad 2.5TDI V6 quattro
    Fully licenced Ross-Tech VCDS Interface
    Air Suspension Compressor Repair Kits: www.bagpipingandy.com
  3. Re: Allroad Air Suspension Compressor strip & repair
    #13
    Sep 2009
    A406
    Kit was £100, hmm made me wonder now. I will post some pictures one day, to me it looks identical, but then I have not taken one appart yet.
    I thought only mounting/wiring points might be different.
    V6 Tdi Power!
  4. Re: Allroad Air Suspension Compressor strip & repair
    #14
    Ayrshire, Scotland
    18 Post(s)
    based on my findings, not concrete evidence , the parts you have bought are the drier unit, which sits on top of the motor, and piston ring with seals and bolts. the drier unit differs slighlty but to be honest you shouldn't need to use it, and you would have to modify it to suit, not much different to look at appart from the cooling vanes on top of the cylinder head differ and there will be a hole in the cylinder head for the Tyres inflater option
    the piston ring is the bit you want, and should be ok.
    regards
    Andy
  5. Re: Allroad Air Suspension Compressor strip & repair
    #15
    Sep 2009
    A406
    Someone reported it is exact fit, just like the old one, but I'll just have to wait and see, otherwise I know where to get another one .
    I will let you know the outcome when I tackle it.
    V6 Tdi Power!
  6. Thumbs up Re: Allroad Air Suspension Compressor strip & repair
    #16
    Apr 2012
    Arandjelovac, Serbia
    Hello everyone from a new member from Serbia. Firstly, thank to Bagpipingandy on excellent post. I had a few questions if someone has the time and mood to answer.
    Is it necessary to do before removing the compressor procedure discharge air, as some guidelines describe, using the diag. equipment and entering the login code?
    After mounting the compressor, how to perform the charging air, and to avoid the risk of bursting air "spring"? I know that the car should be up, ("wheels on air") and the "jack" mode ON.
    TIA,
    Bojan
  7. Re: Allroad Air Suspension Compressor strip & repair
    #17
    Ayrshire, Scotland
    18 Post(s)
    Hi, and welcome.
    removing only the compressor does not make the system to loose pressure, and you do not need to depressurise it and so it is very easy, as long as you can get the nuts off!!.
    no need for vcds to remove or install The compressor. no need to recharge either as no air is lost
    regards
    Andy
  8. Thumbs up Re: Allroad Air Suspension Compressor strip & repair
    #18
    Apr 2012
    Tnx for the welcome, thanks for the everything.
    Bojan
  9. Re: Allroad Air Suspension Compressor strip & repair
    #19
    May 2012
    London, UK
    Good Day,
    Exactley the thread I need. Great information. However, anyone knopw where I can get hold of one of these kits now??
    MArk
  10. Re: Allroad Air Suspension Compressor strip & repair
    #20
    Ayrshire, Scotland
    18 Post(s)
    Quote Originally Posted by mefoote35 View Post
    Good Day,
    MArk
    Hi Mark, the last batch has just finished yesterday on eBay, I will have more on tomorrow or by Friday latest. for ref, on ebay Search allroad compressor repair kit.
    What are your suspension symtoms?
    Regards
    Andy
  1. Allroad suspension compressor purchasing.
    By Tommer9 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 29-03-2012, 10:08 PM
  2. Allroad air suspension compressor
    By douglasiain in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 06-09-2011, 12:38 PM
  3. Allroad suspension air compressor part no
    By vinpetrol in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 09-06-2011, 09:51 PM
  4. Allroad suspension compressor
    By 27allroadpetrol in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 20-04-2011, 02:09 PM
  5. Allroad Suspension Compressor
    By Boothyboy in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 19-08-2010, 08:50 AM
