Thread: What can I do with VCDS?
  1. Thumbs up What can I do with VCDS?
    Mar 2012
    Chippenham England UK
    Hi, I'm new to this forum and also a new Audi owner, but not to VAG range of cars.
    What I would like to know is what are the typical sort of settings can I change with VCDS in terms of how the care operates?
    For example, I have heard of needle swing check on ignition on, increase in number of indicator flashes for momentary use etd...
    What else do people usually go for and am I restricted with my MY A3?
    Thanks in advance to all responders if you can PM me to let me know! Cheers
  2. Re: What can I do with VCDS?
    46 Post(s)
    What year is your a3?
    I have done alarm chirp, drl with rear taillights, cornering fogs, auto lock/unlock doors. You can change the indicator ticks through vcds too.
    Only the s3 and rs3 support needle sweep afaik
  3. Re: What can I do with VCDS?
    1840 Post(s)
    Are you thinking of the shareware, Lite or full version of VCDS?
  4. Re: What can I do with VCDS?
    Ambler, PA, USA
    The Ross-Tech Wiki is your friend! Specifically, the Audi A3 pages will list the coding changes one can make. On the 8P page, there is a link to common tweaks that may be available in your car.
  1. advice on buying VCDS/VCDS-lite
    By borakev in forum VCDS - General Questions
    Last Post: 16-04-2019, 05:20 PM
  2. vcds help
    By derrek in forum VCDS - General Questions
    Last Post: 05-03-2012, 07:36 PM
  3. Question vcds
    By peterpaulogrady in forum Polo - Derby - Lupo - Fox
    Last Post: 16-04-2011, 02:52 PM
  4. vcds help
    By stevo-dtm in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 13-01-2011, 01:23 PM
  5. vcds help
    By dilun in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 19-10-2010, 01:14 PM
