Thread: Bleeding Fuel System on Audi Allroad 2002 2.5TDi AKE
  1. Bleeding Fuel System on Audi Allroad 2002 2.5TDi AKE
    Nov 2011
    Duns Scotland
    11 Post(s)
    Is it possible to bleed the fuel system without using the VAG tool VAG 1348/3A? If so, couold someone please outline the procedure.
    Many thanks in advance.
  2. Re: Bleeding Fuel System on Audi Allroad 2002 2.5TDi AKE
    1840 Post(s)
    Easy, just drop 12v from the battery positive terminal to the output on fuse 28 using a fuse piece of wire.
  1. Dynamically Checking Fuel Pump Timing on 2002 Allroad 2.5TDi Automatic AKE
    By ceilidhalfie in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 15-03-2014, 10:15 PM
  2. Cannot Start 2002 Audi Allroad 2.5TDI Automatic AKE after cam belts changed
    Last Post: 12-07-2013, 06:07 PM
  3. Running AKE Engine of 2002 Audi Allroad 2.5TDI Automatic without the Viscous Fan Installed
    Last Post: 27-03-2012, 08:54 PM
  4. Audi Allroad 2002 2.5TDi AKE - Swingout the Lock Carrier aka "gate style"
    Last Post: 19-02-2012, 10:44 PM
  5. 2002 Allroad 2.5TDi AKE - removing caps on glow plugs
    Last Post: 15-12-2011, 02:02 PM
