Thread: Is the ignition barrel/key barrel/ig. switch the same on 1997 A3 as a 1998 A3? Need to check
  1. Is the ignition barrel/key barrel/ig. switch the same on 1997 A3 as a 1998 A3? Need to check
    Sep 2008
    Just before I buy a second hand complete ignition from ebay I need to check the dimensions on the 97 one I'm buying is the same as my 98?
    I went to the scrappy to source one today The mk4 golf, Seat, A4 and Passat ignitions all looked the same - but alas none had keys!
    Still good fun looking though!
  2. Re: Is the ignition barrel/key barrel/ig. switch the same on 1997 A3 as a 1998 A3? Need to check
    May 2010
    Devon England
    Yes they are mate
  3. Re: Is the ignition barrel/key barrel/ig. switch the same on 1997 A3 as a 1998 A3? Need to check
    1841 Post(s)
    What are you trying to do?
  4. Re: Is the ignition barrel/key barrel/ig. switch the same on 1997 A3 as a 1998 A3? Need to check
    Sep 2008
    I'm trying to change the whole ignition cylinder because the internal 'pin' that goes into the ignition starter has snapped clean off.
    I've sourced a 'new' one with a key/barrel/main cylinder/ignition switch that I'm picking up later.
    I was gonna swap the whole thing out and just use the ignition key from the donor part - do you think this will be ok? Or will I get immobilzer issues?
  5. Re: Is the ignition barrel/key barrel/ig. switch the same on 1997 A3 as a 1998 A3? Need to check
    1841 Post(s)
    You would have to swap the old keys chip into the new key and they are extremely fragile.
  6. Re: Is the ignition barrel/key barrel/ig. switch the same on 1997 A3 as a 1998 A3? Need to check
    Sep 2008
    All done! She lives to see another day.
    I ended up swapping my original key/barrel into the 'new' ignition cylinder and fitted it the whole thing. The hardest part was getting the security bolts off - they do their job!
    I'll put up some pics and a run through of what I did when I get a chance, might help others with the same issue.
    Thanks for the replies
  1. Question HELP with very strange key fob/ignition barrel problem
    By TeaTimeGilly in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-07-2011, 05:49 PM
  2. ignition barrel / switch
    By pbaron in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 04-02-2011, 09:44 AM
  3. Question Ignition Barrel
    By diablo2774 in forum Bora - 1998 - 2005
    Last Post: 14-04-2009, 06:34 PM
  4. Ignition Barrel
    By Wellbelove1 in forum Golf MK2 - 1984 - 1992
    Last Post: 11-03-2008, 01:03 PM
  5. Ignition switch/barrel and starter motor
    By 31satara in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 22-01-2008, 08:25 AM
