Thread: My MMI Screen is very dim...
Results 1 to 10 of 10
  1. My MMI Screen is very dim...
    Aug 2007
    uk
    Hi, I just bought a 08 S-Line and I'm disapointed with the brightness of the MMI screen
    I have tried adjusting the dash light control, and the in menu display brighness control, but it only seems to dim/brighten the display by a miniscule amount
    Its virtually unreadable during daylight hours, and still fairly dim at night
    My previous 07 avant with the RNS-E satnav had a good bright screen
    Have I got a faulty backlight or is this normal?
    thanks
  2. Re: My MMI Screen is very dim...
    Nov 2008
    Suffolk
    sounds faulty to me - on full brightness it should be relatively blinding at night
    2018 Amarok V6
  3. Re: My MMI Screen is very dim...
    Jan 2011
    Bucks
    Quote Originally Posted by Abyss View Post
    thanks
    Agree with jakerade, I have to dim mine at night as it is too bright!
    MY2011 (Apr), A4 B8 Avant, 2.0 TDI 170 quattro technik in Brilliant Red. Full leather, DAB, Lighting pack, 3g MMI HDD Sat Nav, Parking Plus, AMI, Boot liner.
  4. Re: My MMI Screen is very dim...
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    It may be a light sensor fault, as on my A6 all the instrument lighting dims/ brightens according to the outside light.
    Alan.
    VW T6 150 DSG Camper £££
  5. Re: My MMI Screen is very dim...
    Jun 2012
    Solihull
    Hi Abyss
    Ive got exactly the same problem on a 57 plate A5, did you get your screen sorted.
    Cheers.
  6. Re: My MMI Screen is very dim...
    Aug 2007
    uk
    Quote Originally Posted by Siray11 View Post
    Hi Abyss
    Cheers.
    Hi Siray
    Yes, I got it sorted - I picked up a new screen from eBay , and it works perfectly - back to full brightness.
  7. Re: My MMI Screen is very dim...
    Jun 2012
    Solihull
    Nice one, think I'm going to have to do the same. Mines only done 63000 tho which is annoying.
    Was it easy to fit, I hear they are easy to do?, can you remember how much it cost you off eBay.
    Ta.
  8. Re: My MMI Screen is very dim...
    Aug 2007
    uk
    Very easy to fit - the silver plastic shroud just pulls off - just leave the hazard light connected and set it on top of the dash
    then you need a torx driver ( can't remember what size ) to remove the 4 screws, pull out the screen , and unplug the cable .
    Fitting new screen is the same in reverse
  9. Re: My MMI Screen is very dim...
    Jun 2013
    Moscow
    all displays from up to 06.2009 have bugs with backlight.
    if you dont afraid russian language, you are can repait it, need only 148mm CCFL lamp.
    instructions link: http://www.auto-chips.ru/Display-Repair-AMI-MMI.pdf
  10. Re: My MMI Screen is very dim...
    Dec 2008
    12 Post(s)
    Do you know is ccfl lamp under instrument cluster DIS LCD also and which are dimensions? I've changed all white LEDs under instrument cluster gauges but now they are much more brighter than original ones were before so I have to change ccfl under DIS LCD to match with surrounding LED brightnes and color
  1. Scratch on MMI Screen
    By harryg in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 25-11-2011, 09:46 AM
  2. MMI Screen cleaning
    By pxr5 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 22-11-2010, 01:12 PM
  3. MMI screen blank
    By johninvienna in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 24-05-2010, 02:58 PM
  4. Question mmi screen upgrade
    By mattq in forum In Car Entertainment
    Last Post: 13-04-2010, 09:33 PM
  5. Audi A4 Display screen is really dim
    By Cor in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-02-2008, 11:00 PM
