Thread: 1997 Petrol Alhambra - Thermostat location
  1. 1997 Petrol Alhambra - Thermostat location
    Mar 2012
    Reading
    Have searched the internet for help here and found lots of questions but no answersthat helps me.
    My 1997 Petrol, Manual, Alhambra just will not give out heat from theinterior heater anymore. Was never that good from day 1 when new but now thetemp gauge will not lift more than a needle width off the bottom unless I leavethe car running and stationary for half an hour plus.
    So going back to basics I guess the thermostat has stuck open so have boughta replacement. Now the problem - I can't find the location of the housing toreplace it.
    Most suggestion are saying that it is at the engine end of the bottomradiator hose but it is not obviously there to me.
    Could somebody please tell me where I can find the thermostat housing – the wifehas struggled through the winter with no heat to clear the windscreen and now Ijust need to get this fixed.
    Many thanks in advance for any help here.
    Regards
    Colin
  2. Re: 1997 Petrol Alhambra - Thermostat location
    May 2010
    Devon England
    Hi Colin the thermostat housing is on the drivers side of the block behind the alternator IIRC, the hose goes to the bottom of the rad, the housing is bolted up with 2x 10 mm bolts, it does sound like the stats failed in the open position, and a change of stat should see the heater working again
    Phil
  3. Re: 1997 Petrol Alhambra - Thermostat location
    Mar 2012
    Reading
    Phil
    Many thanks - will go and take another look. Many thanks
  4. Re: 1997 Petrol Alhambra - Thermostat location
    Mar 2012
    Reading
    Well it looks as if the thermostat housing must be buried behind the Air Conpump - so will have to wait for another day when I am prepared to strip thatoff as well. Air con is not something I have played with before so not too surehow much I can dismantle without letting all the gas escape. Anyone haveexperience of removing this pump on the Alhambra I wonder?
    Colin
  1. Thermostat repair on alhambra
    By hulse in forum Alhambra
    Last Post: 25-09-2011, 04:04 PM
  2. location of thermostat
    By nskeates in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 05-11-2009, 02:57 PM
  3. Question location of thermostat
    By deansgolf in forum 80 - 90
    Last Post: 06-02-2009, 09:15 AM
  4. Question frost sensor on a 1997 alhambra??
    By jamesey in forum Alhambra
    Last Post: 06-01-2009, 10:47 PM
  5. Question thermostat location
    By reda4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-11-2008, 11:00 AM
