Thread: Allroad 2.5tdi Low Fuel Level Sensor (G210)
Page 4 of 4 FirstFirst ... 234
Results 31 to 34 of 34
  1. Re: Allroad 2.5tdi Low Fuel Level Sensor (G210)
    #31
    Jul 2011
    Norway
    Must admit I havent read this whole thread, but just in case someone find it interesting the ECU throws code for G 210 whenewer the baffle chamber is empty and it will not allow the engine to start before this code is gone.
    Have experienced this several times when replacing/ bleeding the IP. ( could be avoided by running the transfer pump with a wire directly from battery + to fuse 28 ( or 26 ? ) )
  2. Re: Allroad 2.5tdi Low Fuel Level Sensor (G210)
    #32
    Nov 2008
    Have tested the two I have, as they seem fine,because nothing changed when I replaced those two, its the one at the Fuel Pump right Reading 0-57 Ohms and the back middle one reading 30-107 ohms. Have VCDS and found with currently between 25-30 lts in the Tank Iget a reading of 207 Ohms and therefore 45 lts in the Tank. I have estimated the Reading of the two that are Ok at about 60 Ohms together, which then means the other one on the left is buggered.......... Have found a second hand one and ordered...... Peter thanks for your help !
  3. Re: Allroad 2.5tdi Low Fuel Level Sensor (G210)
    #33
    Sep 2019
    Belgrade & Serbia
    G210 is the sensor in the baffle housing. I think that combination of low fuel in the reservoir and low fuel in the baffle housing both at the same time give ECU signals not to allow starting the engine in order to prevent air getting into high pressure fuel pump.
  4. Re: Allroad 2.5tdi Low Fuel Level Sensor (G210)
    #34
    Jan 2015
    Israel Kfar uriya
    9 Post(s)
    The ECU can tell the difference between disconnecting the G210 to the sign of a lack of fuel.
  1. Allroad Level Sensor Electrical Problem
    By snugglebum in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 20-01-2021, 04:46 PM
  2. Allroad Level Sensor Changing / Leaking Suspension
    By jonnboy32 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 26-04-2012, 07:10 AM
  3. Allroad level sensor
    By allan_audi in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 25-03-2011, 09:19 PM
  4. 01441 low fuel level sensor
    By philfingers in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 09-03-2010, 12:09 AM
  5. g210 low level fuel sensor
    By zorgman in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 01-06-2009, 03:30 PM
