Thread: Allroad 2.5tdi Low Fuel Level Sensor (G210)
Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 34
  1. Re: Allroad 2.5tdi Low Fuel Level Sensor (G210)
    #21
    Ayrshire, Scotland
    18 Post(s)
    Info sent, check you e-mails,
    Guage works although I still get nervous now at 40 miles left , i check the resistance now and again, and it is still 30ohms at bottom stop,
    The rear sender is easiest to check and was the problem with mine, it tends to spend most its life out of the fuel hence perhaps the corrosion. basically if you have (approx) 1/4 tank check the rear level sender resistance, accessable under boot floor check 2 sender connections, or under rear passanger seat and check the 2 connector connections (not sender). it should read 30 Ohms if sitting at the bottom stop and 91.5 Ohms top stop (removing the sender gives the benifit of testing it throught its range), the e-mail I sent has all values you may require to check all senders
    regards
    Andy
    2001 Audi A4 Saloon 2.0
    2000 Audi Allroad 2.5TDI V6 quattro
    Fully licenced Ross-Tech VCDS Interface
    Air Suspension Compressor Repair Kits: www.bagpipingandy.com
  2. Re: Allroad 2.5tdi Low Fuel Level Sensor (G210)
    #22
    Nov 2008
    Does Anybody still have the Values Ohm Values for all three Sensors from Bottom and Top, Battling for a year with this already.......... ?
  3. Re: Allroad 2.5tdi Low Fuel Level Sensor (G210)
    #23
    Jul 2008
    I replaced all 3 senders with new Audi units.
    Still hasn't done the job.
  4. Re: Allroad 2.5tdi Low Fuel Level Sensor (G210)
    #24
    Nov 2008
    There is apparently still a Voltage Regulator in the Dash Cluster involved, you should get 4-5 Volt at each sender, if I remember correctly...............
  5. Re: Allroad 2.5tdi Low Fuel Level Sensor (G210)
    #25
    Jul 2008
    But if i had an inaccurate voltage reg for dash,wouldn't other gauges read inaccurately?
    i just remember my capri mk1 with same fault lol, and a few gauges read wrong then.
    (Just for reference, I'm not that old, its a classic car I've had for a few years!!)
  6. Re: Allroad 2.5tdi Low Fuel Level Sensor (G210)
    #26
    G210 low level 100 ohms full 430 ohms
    G1 10 - 70 ohms
    G169 20 - 118.5
    G237 30 - 81.5 ohms
    Regards Peter
  7. Re: Allroad 2.5tdi Low Fuel Level Sensor (G210)
    #27
    The 3 sensors are wired in series thus a max resistance of 270 ohms.
    G210 is wired directly to the Diesel Direct Injection Control Unit and does shut the engine down to avoid wrecking the pump and filing the pipes with air. The device has a resistance of 100 ohms and if the is enough fuel then a 330 ohm resister is switched in thus 430 ohms. Regards Peter
  8. Re: Allroad 2.5tdi Low Fuel Level Sensor (G210)
    #28
    Nov 2008
    I actually have have the Petrol (Otto) 2.7l, but according to ETKA the Diesel and Petrol are the same Sensors in the Tank, as per attached Picture. Peter can you please point out which Sensor is which ie. Right at Fuel Pump, Left and middle in the Back. Thanks....Attachment 20061
  9. Re: Allroad 2.5tdi Low Fuel Level Sensor (G210)
    #29
    Exactly what model car do you have and what engine code. Regards Peter
  10. Re: Allroad 2.5tdi Low Fuel Level Sensor (G210)
    #30
    Nov 2008
    Peter, its a 2001.5 (Basically 2002) with an ARE Engine. My Gauge shows full, then 3/4 on the Gauge is about half Tank and just before 1/4 its empty. Jet pump seems to work as filling up is consistent with Readings I get. Have changed the right Fuel Sender at the Fuel pump already and now the middle Back one, both were from eBay, but the Result was the same. Will post the Readings a bit later of those two Senders......Thanks
  1. Allroad Level Sensor Electrical Problem
    By snugglebum in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 20-01-2021, 04:46 PM
  2. Allroad Level Sensor Changing / Leaking Suspension
    By jonnboy32 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 26-04-2012, 07:10 AM
  3. Allroad level sensor
    By allan_audi in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 25-03-2011, 09:19 PM
  4. 01441 low fuel level sensor
    By philfingers in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 09-03-2010, 12:09 AM
  5. g210 low level fuel sensor
    By zorgman in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 01-06-2009, 03:30 PM
