Thread: inlet manifold removal 2.3 10v engine Audi 80 Cabriolet
  1. inlet manifold removal 2.3 10v engine Audi 80 Cabriolet
    Jun 2009
    caterham Surrey
    Hi All,
    Car failed emissions on high O2 sensor.
    Plugging in probe direcly into engine- shows un burnt fuel in combustion chamber.
    Garage are pretty sure I have an air leak - likely cause inlet manifold gasket.
    Firstly is this a common fault?
    Secondly, can anyone point me in the right direction on how to remove the inlet manifold? Is there a "how to" thread about or an electronic manual someone might have.
    Many Thanks
    Russell.
  2. Re: inlet manifold removal 2.3 10v engine Audi 80 Cabriolet
    Sep 2011
    Isle of Man
    first thing i would do is take your spark plugs out and check the condition of them, are they clean/black perfect or corroded? that will help us massively.
    also, any changes in performance?
    yes all common faults, chance O2 sensor but get a good brand
  3. Re: inlet manifold removal 2.3 10v engine Audi 80 Cabriolet
    1837 Post(s)
    Inlet manifold gasket failure is not at all common on the NG engine (other air leaks are), you need to get this to someone who knows the NG KEIII Motroinic engine as they are odd and very difficult to set up.
  1. Replies: 3
    Last Post: 06-03-2013, 03:45 PM
  2. Cold running engine, excess oil from inlet manifold
    By borabear in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-11-2012, 09:16 PM
  3. Inlet manifold
    By mmeech in forum Golf MK5 - 2004 - 2009
    Last Post: 28-02-2011, 12:33 PM
  4. Please Help inlet manifold leaking
    By chapterg8 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-10-2008, 12:46 PM
  5. Inlet manifold??
    By russvr6 in forum Golf MK3 - 1993 - 1999
    Last Post: 23-08-2008, 06:33 PM
