Thread: Cruise control fitting service nr Manchester
Results 1 to 10 of 16
  1. Cruise control fitting service nr Manchester
    May 2009
    Saddleworth, Yorkshire
    I have seen numerous mobile fiiters advertising on ebay, ie
    http://www.ebay.co.uk/itm/FULL-FITTI...item43ad6eea71
    However these guys always seam to be located down south and I live inbetween Manchester and Huddersfield.
    Can anyone recommend someone more local to me ? My vehicle is a 55 plate 2.0 tdi S Line Avant without a MFSW so I don't know if I will need a new control module
    Thanks Ian
    Southern County Softy
    20 Post(s)
    Send a PM to A8tech.
    From a phone that's smarter than me...
    A4 2.5 tdi QS (mapped)
  3. Re: Cruise control fitting service nr Manchester
    May 2009
    Hi, am I missing something or have you not send a message ?
    Cheers Ian
    20 Post(s)
    YOU send a PM to the user A8 tech
    May 2007
    knee deep in clunge
    14 Post(s)
    Quote Originally Posted by ihs61 View Post
    Thanks Ian
    You will need a new steering column control unit revision r or q
    Cruise switch
    Lower cowling to accommodate the new switch
    Also I advise a new clutch switch
    Then pm me for fitment total labour time 1 hour
    The column control unit is around £130
    Cruise switch £28
    Lower cowling £25
    Clutch switch £11
    Sent from my iPhone using
    My fat fingers
  6. Re: Cruise control fitting service nr Manchester
    Jun 2006
    Fev
    Can recommend A8, fitted mine with no problems.
    A5 3.0 TDI
    Feb 2010
    staffordshire
    A8tech is the man and he is fairly local to you too.
    Full vcds HEX-USB-CAN Interface available in the staffordshire area PM me
  8. Re: Cruise control fitting service nr Manchester
    May 2009
    Just had the cruise fitted by A8tech, superb job and top chap, nice to know who are the good guy's.
  9. Re: Cruise control fitting service nr Manchester
    Apr 2012
    Cumbria
    How much does it cost in total?
  10. Re: Cruise control fitting service nr Manchester
    May 2009
    I had to buy, the switch, lower cowel, clutch sitchand the column control unit these came to £239 + £50 for fitting. I could have saved 160 but needed the control unit
  1. Fitting Cruise control
    By TheMadhatter in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-02-2012, 06:03 PM
  2. Question Fitting Cruise Control to A4
    By saj.3 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 04-10-2011, 09:08 PM
  3. Cruise control fitting
    By n8343454 in forum Golf MK4 - 1999 - 2004
    Last Post: 17-06-2009, 09:47 PM
  4. Fitting cruise control...
    By screech in forum Golf MK4 - 1999 - 2004
    Last Post: 16-05-2009, 07:59 AM
  5. Fitting cruise control
    By diyer in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 19-07-2007, 07:00 PM
