Thread: Can I use "Automatic Transmission Stop Leak" to fix my manual gear box leak?
  1. Can I use "Automatic Transmission Stop Leak" to fix my manual gear box leak?
    Aug 2009
    Surrey
    My wife's car has developed a leak from the transmission. It's bad enough to need fixing but not sever i.e. over a week the level in the box dropped about 10mm.
    I found an additive which is supposed to stop such leaks but it's for automatics not manuals.
    Does anyone know if I can add it to the manual gearbox oil?
    Here's a link: "Wynn's Automatic Transmission & Power Steering Stop Leak"
    http://www.halfords.com/webapp/wcs/s...egoryId_255219
    Martin
  2. Re: Can I use "Automatic Transmission Stop Leak" to fix my manual gear box leak?
    Aug 2009
    Surrey
    I have since found 'stop leak' additives for manual transmissions on ebay. Does anyone know if they are any good or likely to make things worse?
    http://www.ebay.co.uk/itm/1706259536...9#ht_878wt_806
    http://www.ebay.co.uk/itm/2906669118...#ht_1468wt_682
    http://www.ebay.co.uk/itm/2609152677...ht_2494wt_1152
    http://www.ebay.co.uk/itm/3006237822...#ht_3228wt_754
    Martin
  1. Replies: 11
    Last Post: 13-08-2011, 08:28 PM
  2. Replies: 3
    Last Post: 07-09-2010, 10:19 PM
  3. "how to" fix lock on golf mk3
    By stumpfy in forum Golf MK3 - 1993 - 1999
    Last Post: 21-01-2010, 08:47 PM
  4. Radiator leak stopped with stop leak
    By BLASTER in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-08-2008, 08:16 PM
  5. Eos still leaks after lubrication and "fix"
    By pjgraham86 in forum Eos
    Last Post: 25-10-2007, 01:59 PM
