Thread: No throttle response
  1. Unhappy No throttle response
    Dec 2011
    Newport UK
    Good morning
    I'm sure this has been has been covered before, but having searched I am still at a loss.
    First some background, my 30m daily commute constists of Mway/DCway/2lane rural, so from the off my speeds are generally high.
    This morning i was over-taking at around 85/90 (privately-owned section of DC ) and gave the car a little more throttle - with zero results!!! A complete flat-spot!!
    The car was point blank refusing to accellerate, and everytime I would remove/replace my foot the car would settle at whatever speed the car had slowed to.
    When I got an opportunity, I switched the car off and restarted - with little improvement, the car felt laboured to accelerate with a small (slightly lazy) surge at around 3k revs. Whereas before the car would pull quite stongly at any revs regardless of gear.
    No flashing lights, no message on the MFD - What is going on?
    Car in question: 2006 (55) Jetta 2.0TDI PD Sport (140) - Completely standard, 73k miles.
    I would appreciate any thoughts/Ideas/suggestions you may have.
    Many thanks
    Brawn
  2. Re: No throttle response
    Jan 2009
    towcester northants
    diag test first if you can
    check turbo actuator free movement and vac hoses to it
    check air mass meter readings
  1. Question Uneven throttle response
    By GFP in forum General Detailing/Cleaning Questions
    Last Post: 05-09-2011, 09:33 AM
  2. Please Help No Throttle Response
    By pazz in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-04-2011, 08:03 PM
  3. Question throttle response
    By tekki in forum Beetle 2000-
    Last Post: 07-03-2011, 02:44 PM
  4. A4 B5 2.8 Quattro Throttle Response
    By antony.w in forum VCDS - General Questions
    Last Post: 21-02-2010, 11:21 PM
  5. Please Help No throttle response
    By hoggster in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-01-2010, 08:15 PM
