I have just found that I can't open the boot. It opened OK before except that I sometimes had to try a couple of times with the handle.
The key lock is in the correct position and using the electronic lock and unlock you can hear the solenoid in the boot. However turning the key in the boot does not activate the locking or unlocking of the car.
How do I open the boot assuming that I will be working from inside the car?
Thanks.
