Thread: A6 1.9 TDI 5 speed manual gearbox
  1. A6 1.9 TDI 5 speed manual gearbox
    Feb 2012
    carmarthen uk
    my gearbox has started making a rattling noise, rattles when idling, when clutch engaged still makes a noise.\no problem changing gears. Any ideas as to what may be problem? Thanks
    Moved from chat section
  2. Re: A6 1.9 TDI 5 speed manual gearbox
    If you press the clutch and engage a gear nothing is rotating in the box. However what you describe could well be failing Dual Mass Flywheel. Regards Peter
  3. Re: A6 1.9 TDI 5 speed manual gearbox
    Feb 2012
    carmarthen uk
    thank you , have taken to garage this morning and its exactly that, the flywheel, need new clutch as well apparently. thanks for your help.
  4. Re: A6 1.9 TDI 5 speed manual gearbox
    What did they quote you for the parts and labour. Regards Peter
  5. Re: A6 1.9 TDI 5 speed manual gearbox
    Feb 2012
    carmarthen uk
    Prices vary most expensive 134 for clutch, 300 for flywheel and 247 for 5.5hrs labour.
    Cheapest 649 all in. Does this sound about right?
  6. Re: A6 1.9 TDI 5 speed manual gearbox
    Sounds cheap for a sachs or OEM DMF, pressure plate, clutch and release bearing. Audi would charge you £1300/1400 Regards Peter
  7. Re: A6 1.9 TDI 5 speed manual gearbox
    Feb 2012
    carmarthen uk
  1. 2.0 TDI Manual Gearbox Problems
    By jakerade in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 23-06-2011, 05:08 PM
  2. 1999 A4 1.9 TDI Gearbox 5 speed
    By feckers in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 23-05-2011, 02:47 PM
  3. 6 speed manual gearbox noise
    By paul.mgrath in forum Golf MK6 - 2009 - 2013
    Last Post: 25-05-2010, 09:07 PM
  4. Please Help 2006 2.0 Tdi 140 6 Speed Manual Gearbox Failure - Terminal !!
    By shaun3030 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 02-12-2008, 07:50 PM
  5. HELP ! 03 Passat tdi sport 6 speed gearbox problem
    By spadders in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-08-2007, 07:32 AM
