Thread: CamShaft Sensor Location
  1. Question CamShaft Sensor Location
    Mar 2011
    worcestershire
    Golf MK5 1.9tdi 2005. Engine BKC
    Where is the location of the Camshaft Sensor. VW 036 906 433E (this might now be 045 906 433A?)
    Have Excessive Hot Start Cranking issue. (no code errors)
    Have removed air filter box but dammed if I can see it.
  2. Re: CamShaft Sensor Location
    May 2010
    Devon England
    its at the cam belt end iirc mate, how fast does your starter crank the engine over? the starter motor is a known fault with hot start issues
  3. Re: CamShaft Sensor Location
    Mar 2011
    worcestershire
    How can I find out my cranking rpm? Av vcds.
  4. Re: CamShaft Sensor Location
    Mar 2011
    worcestershire
    Golf 1.9tdi 2005 Engine BKC.
    Still cannot find Camshaft sensor.
    Have looked underneath both ends of crankshaft.
    (Have removed Starter Motor, Stripped & greased). (com & brushes look perfect).
    Where is this sensor?
    Last edited by golf144; 09-02-2012 at 01:22 PM. Reason: Swear filter is there for a reason!
  5. Re: CamShaft Sensor Location
    Mar 2011
    worcestershire
    Have just replaced STARTER MOTOR & now turns over faster when cold & even faster when hot & now fires 1st time.
    Thanks Phil Miller you where spot on.
    (got a S/H replacement off a 2010 golf, same pt. but a later year code. £50 Ebay - result)
  6. Re: CamShaft Sensor Location
    May 2010
    Devon England
    Quote Originally Posted by golf144 View Post
    Fantastic well done mate, i must get round to replacing mine asap.....
    Glad its all sorted
  1. Replies: 3
    Last Post: 26-05-2011, 12:07 PM
  2. Please Help Camshaft sensor
    By Stoddiegal in forum Bora - 1998 - 2005
    Last Post: 13-11-2010, 08:59 PM
  3. Question Camshaft sensor
    By MOUSE7 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-10-2009, 01:21 PM
  4. Replies: 8
    Last Post: 07-02-2009, 11:21 PM
  5. Question Camshaft Sensor
    By malcolm tripp in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-12-2008, 12:44 PM
