Thread: Water settling in drivers footwell
  1. Water settling in drivers footwell
    Jan 2012
    Newbury, Berkshire, UK
    Hello all, im new to the forum and was hoping somebody may be able to enlighten me on a ongoing problem i have.
    I have a 1996 1.8t saloon. For a very long time now (maybe four years) i have had water collecting in the drivers footwell. I have had a VW audi specialist ( the Turners, stonehouse) look at it many times but the problem is still there.
    Its not:
    Collecting under the battery, both drainage bungs have been totally removed and its clear
    Coming in through the bonnet release catch hole (siliconed up)
    Coming in behind the ECU (siliconed up)
    coming in through the pollen filter (totally dry, and would probably affect pas footwell)
    coming in through the driver/rear passenger window seal > door membrane (hosepipe test!)
    I dont think the water is coming in when the car is stationary, and have checked underneath for damage and where it may breach the body. I cant find a thing. Sense tells me it must be rainwater going down the windscreen and getting through somehow, somewhere... but im buggered if i can find out where!!
    I have dredged the internet and this forum for info but cannot find anything useful, apart from it could be from a blocked sunroof drain? can anybody enlighten me how i would go about looking at this? or can anybody suggest anywhere else to look???
    thanks very much
    A damp A4 owner
  2. Re: Water settling in drivers footwell
    Sep 2008
    6 Post(s)
    2016 BMW i3 REx (25k)
    2012 A4 Allroad Quattro 2.0 TDI (55k)
    2003 A2 1.4 TDI SE (166k) sold
    2001 B5 A4 2.5 TDI Avant Quattro Sport, (173k), sold
    1995 B4 80 1.9 TDI Avant SE, (175k), sold
  3. Re: Water settling in drivers footwell
    Jan 2012
    No, the car is not losing any water, i've had this problem for 4 years!
  4. Re: Water settling in drivers footwell
    Sep 2011
    glasgow scotland
    have you tried getting someone to run a hose on it while you searchunder the dash with a large bright torch failing that try taking off the wing liner and check for damage behind the wing for missing seal or cracks
  5. Re: Water settling in drivers footwell
    Dec 2009
    southampton uk
    Sunroof drains could need clearing.Do you see any sign of water collecting round them and dripping inside.When I last had a s/roof I used to have a thin plastic tube to push in them and blow through
  6. Re: Water settling in drivers footwell
    Sep 2008
    6 Post(s)
    Quote Originally Posted by mikeybutch View Post
    Plastic strummer cord works treat. Use hot water to rinse through.
  1. Please Help Golf mk 4 water in the drivers footwell only
    By kcleighb in forum Golf MK4 - 1999 - 2004
    Last Post: 25-07-2011, 04:53 PM
  2. Please Help Water in drivers footwell
    By dengrad in forum Alhambra
    Last Post: 05-12-2010, 11:08 PM
  3. help water in drivers footwell!
    By kangtdi in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-06-2008, 09:20 PM
  4. Water getting into drivers footwell?
    By Digidick in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-03-2008, 07:37 PM
  5. Water in drivers footwell !!
    By waylonbuddy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-08-2007, 12:23 PM
