Thread: camshaft sensor fault.
  1. camshaft sensor fault.
    Aug 2009
    southampton
    Hi my a3 2.0fsi on a 04 sometimes fails to start. when i plug it into a snap on reader is says theres a problem with the camshaft sensor. I replaced this with a new one from audi but still the car sometimes wont start. It drives really well when it starts. When it dosent start if i plug it in and reset the camshaft sensor code it then starts. Weird! Can anyone help
  2. Re: camshaft sensor fault.
    Aug 2009
    southampton
    Quick update. Changed the crank/speed sensor with an after market one and coolant temp sensor and had auto elec check it over but still can struggles to start after a long drive.
    Any advice. Will it be worth taking it to main dealer
  3. Re: camshaft sensor fault.
    Hi, Did you get this fixed I have the same problem?
    cheers
  1. Fault code 19463 Camshaft position sensor
    By elliebumpkins in forum Golf MK5 - 2004 - 2009
    Last Post: 28-01-2012, 10:54 PM
  2. Fuses related to the Camshaft sensor fault
    Last Post: 17-01-2012, 06:11 PM
  3. Replies: 3
    Last Post: 26-05-2011, 12:07 PM
  4. Replies: 8
    Last Post: 07-02-2009, 11:21 PM
  5. Question Camshaft Sensor
    By malcolm tripp in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-12-2008, 12:44 PM
