Thread: Golf VI TDI S 105 poor fuel consumption
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. Re: Golf VI TDI S 105 poor fuel consumption
    Oct 2009
    Eyemouth, Scottish Borders
    Quote Originally Posted by steve67 View Post
    hi, my 2012 golf has been back twice for poor mpg, but nothing found, i get way below quoted figure..
    all was fine until i filled up at Morrison's , since then its never returned to what i was getting, saying that most of our driving is in and around town, just got told by vw , these engines are sensitive to the weather temp
    It's worth checking that the brakes aren't sticking on. Chock the front wheels and jack up the rear wheels one at a time. They should turn freely, albeit with a little rubbing noise. (Obviously with handbrake off.......) The rear discs in particular tend to accumulate rust around their periphery which then works its way over the surface. If they are rubbing, a good mechanic should be able to chip the rust off, which is cheaper than new discs and pads. The pads also tend to stick in the calipers - about 3 years old is often when these little games start. Front discs are more tricky to check. Any friendly garages nearby who could check them out for you? Ironically, powerful cars with effective disc brakes are often prone to such problems when driven gently. That's life!
    2009 1.6 TDi 105 5 door Tornado Red
  2. Re: Golf VI TDI S 105 poor fuel consumption
    May 2011
    Hi Steve, these engines are definitely sensitive to temperature. This may be an issue with mine if a temp sensor is defective, but that should show at diagnostics. With the recent higher temps, my TDI s is returning 65-66mpg, but the TDI se is 46-47 and I'm driving both like a fairy. Oh and they are both filled at the same garage (Esso). I'm sure I will get to the bottom of the problem eventually!
  3. Re: Golf VI TDI S 105 poor fuel consumption
    Jan 2018
    Doncaster
    Hi have you got to the bottom of the problem ? I have a golf VI dsg 7 gears with similar problem I am getting 37 mpg , about 350-375 per full tank of fuel . and this started from August last year so is not the winter diesel . I was previously getting 50+ going to same job since got the car 3 years ago . Can you please advise me what can be done cheers
  4. Re: Golf VI TDI S 105 poor fuel consumption
    Quote Originally Posted by andrei View Post
    Hi there, I stumbled on this thread as I have the same car spec as yours. I too have queried why I have such bad fuel economy...I only average 44.7mpg based on over 2 month analysis. Surely our cars can't be that way off from official figures? Did you happen to get to the bottom of it?
  5. Re: Golf VI TDI S 105 poor fuel consumption
    Sep 2020
    Warrington
    Hello
    Just purchased a Passat with 1.6TDi CAYC, Full service history and just had major service all filters replaced, very well maintained, usual checked tyre pressures sticking brakes. The MPG is shocking, early 40s on m/way run when you would be expecting mid 60s. I see it seems to be a common problem, has anyone found the ‘smoking gun’?
  1. 2.0 tdi poor fuel consumption AUDI a6
    By bosworth in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 18-01-2021, 11:22 PM
  2. Question TDI 130 poor acceleration and fuel consumption
    By Dylan323 in forum Golf MK4 - 1999 - 2004
    Last Post: 01-02-2012, 11:27 PM
  3. Please Help audi A4 tdi 170 poor fuel consumption
    By toneman in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-01-2009, 11:01 AM
  4. Gearing/fuel consumption 1.9tdi 105 plus
    By alibaly in forum Golf Plus
    Last Post: 26-02-2008, 08:22 PM
  5. 97 Golf MK3 has very poor fuel consumption
    By beeson in forum Golf MK3 - 1993 - 1999
    Last Post: 11-02-2008, 05:00 PM
