Thread: Cooling System
Page 1 of 3 123 LastLast
Results 1 to 10 of 22
  1. Cooling System
    Sep 2007
    Plymouth
    Hello individuals.
    My 2003 1.9tdi awx is loosing coolant. I cannot see any external leaks, but me fearing a head gasket leak has asked a local garage to have a look.
    Apparently, the coolant is not circulating, so they expect a faulty water pump. If the water pump is at fault, where would the coolant be going? Also, the car is not showing any overheating symptoms and the heating still works, which I would expect to be happening if the pump was faulty.
    Any extra ideas much appreciated.
    2003 A6 1.9TDI PD Avant SE 359,000 miles
    Cannondale Road Bike
    Yeti ASR SL Mountain Bike
    9ft 4inch Surfboard (two of)
  2. Re: Cooling System
    Mar 2008
    High Wycombe
    it depends on what they mean by faulty. If the fault is that the impeller vanes have broken, then it won't be leaking, but will not circulate water. If the car then overheats, the pressure will force water out through the expansion bottle cap. If the water pump is leaking, then you'd see water drips / coolant residue below it or around the pulley.
    How have they diagnosed lack of circulation? I can't see through the hoses on mine to see if the water is circulating. Do you trust your local garage, or could they be guessing it's the water pump?
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
    Sep 2009
    ramsgate
    The pump can be failing to varying degrees
    I found mine used to heat the cab at low speed but slip at highspeed and blow cold air. This time of the year the pump may be coping to varying degree despite the fact its knackered
    It can come off the shaft and just slip
    Either way it sounds like a new pump needed
    Sep 2009
    ramsgate
    Sooner rather than later, if your header tank is blowing coolant its probably overheating
    Is your top hose hot and bottom hose warmish after 2 miles?
  5. Re: Cooling System
    Sep 2007
    Plymouth
    The header tank hasn't been pressurised at all.
    Collecting the car shortly; I hope they investigated more than just feeling that the bottom of the radiator was cold, when the top was hot for their hours labour charge!
  6. Re: Cooling System
    7 Post(s)
    I've just been through this exact problem on my AWX'd passat but without water loss.
    It was the water pump.
    As for top and bottom hoses getting hot, you'll be lucky to feel any heat in the bottom hose at this time of year even after running for 30+ miles. The you should feel heat in the top hose fairly soon though.
    Sep 2009
    ramsgate
    Hot top hose and you pumps working, no garentee it's working efficiently though
    Garage will know that, do you trust them?
    Sadly if you can't do it yourself it's not a cheap job
    Sep 2009
    ramsgate
    HG usually shows emulsified oil (creamy colour froth) at the oil filler dependent on which direction the gasket has blown of course
    The garage can presurize the cooling system and look for leaks.
    How much you losing?
  9. Re: Cooling System
    Sep 2007
    Plymouth
    Many thanks for the input.
    Difficult to comment on how much I'm losing accurately as I've not measured yet. My daily commute (there and back) is 130 miles, at an average of 65mph, and I reckon I'm losing 350ml - 500ml a day.
    The oil looks clear of water contamination.
    This is the first time at this particular garage today. Gut feeling is I'm not impressed.
    I've had look this evening with a torch and can see dampness/moisture on top of the gearbox, driver side behind engine. I can't work out if that is spilt oil from the filler cap, or is coolant - too dark and my arm wouldn't fit into the gap. I'll have to wait to weekend now for a better look in daylight and more time to take the intercooler pipe out of the way.
    The cambelt is due for a change, but I'm hesistant of cracking on with that if it turns out the HG is starting to go.
    Sep 2009
    ramsgate
    Where you describe is where the coolant temp sensor is, green or black plug onto the block, might be leaking
    Be nice if that was it, bout 15£ diy
  1. Question Cooling system
    By NOSNI in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-07-2011, 07:08 PM
  2. Question Cooling system
    By herbie in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 27-02-2011, 07:49 PM
  3. flushing cooling system
    By lawser in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 02-01-2011, 07:31 PM
  4. Mk 3 cooling system
    By britishwardog in forum Golf MK3 - 1993 - 1999
    Last Post: 21-02-2010, 09:55 AM
  5. cooling system
    By billza1967 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-02-2008, 02:29 PM
