Thread: A6 Climate Control/Heating problem
Results 11 to 20 of 24
  1. Re: A6 Climate Control/Heating problem
    Apr 2015
    bolton
    brilliant, thanks so much for that, will try it later and let you know
  2. Re: A6 Climate Control/Heating problem
    Jan 2012
    Dublin, Ireland
    Please do - I'd love to hear how you get on! I'm keeping my fingers crossed for you!
  3. Re: A6 Climate Control/Heating problem
    Apr 2015
    bolton
    hi just thought I'd update with exactly what ive done
    drove the car for 20 mins, motorway and around town. parked up, left the car running and slowly opened coolant cap, heard a fizz as though air was being released and then coolant spilled.
    I then sat in the car for 2/3 mins to see if heat changed, it didnt.
    Left the car for a couple of hours and repeated again, no change in heat.
    In the meantime i have told my mechanic about your suggestion and he is going to try and obtain a vacuum bleeding tool to use on system.
    will keep you posted
    thanks again
  4. Re: A6 Climate Control/Heating problem
    Jan 2012
    Dublin, Ireland
    Quote Originally Posted by byronjohnson View Post
    thanks again
    Ahhh bugger, was really hoping this would work for you! Really sorry it didn't work for you - it's problems like this that make me hark back to the good ol' days of simple mechanics, when something like this could have been solved with a lump hammer and some gaffer tape! :0/
    I'll keep fingers crossed your mechanic can sort it via the vacuum method then - let us know how you get on!
  5. Re: A6 Climate Control/Heating problem
    Southern County Softy
    20 Post(s)
    Have you seen this thread.
    Air con blowing hot on passenger side
    A4 2.5 tdi QS (mapped)
  6. Re: A6 Climate Control/Heating problem
    Jul 2013
    76 Post(s)
    Opening a hot coolant expansion bottle is very dangerous and should not be recommend as a way to bleeding the system.
    The correct way is to use the bleed screws on the pipework/ radiator.
    Dan
    2009/2010 2.0 TDIe SE
  7. Re: A6 Climate Control/Heating problem
    #17
    Jul 2013
    76 Post(s)
    Have you got the centre vents in the MMI set to cold?
    Dan
  8. Re: A6 Climate Control/Heating problem
    #18
    Apr 2015
    bolton
    mechanic performed vacuum bleed of the whole system and it now works perfectly
    really appreciate you coming back to me on this one, had completely run out of options
    cheers
    2 2 0
  9. Re: A6 Climate Control/Heating problem
    #19
    Jan 2012
    Dublin, Ireland
    Not a problem at all my man! Trust me, I know exactly how you were feeling - so delighted I was able to help!
    cheers
  10. Re: A6 Climate Control/Heating problem
    #20
    Apr 2015
    fauske
    Hello. The error code that you have on the circulation pump indicates that there is air in the system. Nothing wrong with the pump. Because of air in the system, so the pump go much faster. It is because of that error code is added.
    Some are very difficult to air bleeding, Thinking you have to stand on 1800-2000 rpm for the air is out. may take up to 4 hours.
    Run the engine warm, parks flat or with motor at the highest point. Remove the lock of the expansion tank slowly. Fill up the tank for and so keep the car on 1800-2000 rpm that the air is gone. make sure the tank is constantly full.
    Stian, Norway
    Google translate; D
  1. Please Help Climate Control Problem.
    By Yeadonchap in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 29-09-2011, 09:19 AM
  2. Question Sharan Flashin Manual Heating Control Problem
    By dundia in forum Touran - Sharan - Caravelle
    Last Post: 09-04-2011, 06:03 PM
  3. Please Help Rear heating vents (climate control)
    By gingernut352000 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 19-01-2009, 12:37 PM
  4. Replies: 2
    Last Post: 08-08-2008, 10:53 PM
  5. Semi-automatic climate control/heating question.
    By BenR in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 06-06-2008, 12:54 PM
