Thread: Radio reception problems Mk5 Golf 2004 rcd300
Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
  1. Re: Radio reception problems Mk5 Golf 2004 rcd300
    Kinross Scotland
    VCDS= Vag- Com Diagnostic System is made by an American company called RossTech. It can scan and be used to correct faults ect in all VAG Mfd. vehicles. It is also expensive unless you are using it a lot (£270). Go to their webpage for more detail
    Ross-Tech: VCDS Tour
    Tiguan 2.0 4Motion 140PS 01/07/2013
  2. Re: Radio reception problems Mk5 Golf 2004 rcd300
    Kinross Scotland
    VCDS = Vag-Com Diagnostic System . MFd. by Ross-tech. Ross-Tech: VCDS Tour
    IT works on all VAG Mfd. vehicles and is almost as good as the dealer diagnostic system called VAS. costs circa. £270 from Gendan in the UK.
    Ebay has Chinese clones but not recommended on this forum.
    sorry for the double post but the 1st one took a long time to show up.
  3. Re: Radio reception problems Mk5 Golf 2004 rcd300
    Feb 2014
    Hertfordshire
    I see a lot of these mk5's with signal problems usually the main offender is a leak in the rear washer pipe which causes the connections and wiring loom to corrode giving weak or no signal. Can be fixed ordering new cable from a main dealer and connectors but you will need to know if it is a single wire or dual. Also connected are two boosters which as above I think states you might be able to scan for with the right scanner.
  4. Re: Radio reception problems Mk5 Golf 2004 rcd300
    Feb 2014
    Berkshire
    Dear Members,
    Many thanks for the help and advice it has being most informative for someone who knows very little about cars this is a great learning curve, next step is to find a radio specialist
    Kind regards
    Walter
  5. Re: Radio reception problems Mk5 Golf 2004 rcd300
    Kinross Scotland
    A very logical explanation causing the loss of signal
  6. Re: Radio reception problems Mk5 Golf 2004 rcd300
    Feb 2014
    Berkshire
    Hi Richard,
    Do you have any idea what sort of money I will likely have to pay in order to sort out the problem or should I wait until the fault is found before asking this question
    Kind regards and thanks for the help
    Walter
  7. Re: Radio reception problems Mk5 Golf 2004 rcd300
    #17
    Kinross Scotland
    Morning Walter,
    Most charges for labour I would expect to be around £50 per hour and at the dealer £70. A car radio specialist might give you a quote all in.
    Parts needed ie cable and tailgate amp could run to around £70 so I think to have someone do the job for you professionally a ball part figure of £150 is not too far off the mark.
    Do you have a friend who could help you then you only have the parts and beer token costs. Remember to isolate the battery if you mess around with the wiring.
    I can supply you some workshop info if you try to tackle it yourself but you will have to give me a private email address via the PM system.
    I will not be around for the next two days.
  8. Re: Radio reception problems Mk5 Golf 2004 rcd300
    #18
    Feb 2014
    Berkshire
    Dear Richard,
    Many thanks for the offer but it's beyond my expertise so I will let the garage sort it out when funds allow as the boiler is playing up !!!!!!!!!!!! happy days !!!!!
    Kind regards and again thanks for all the help and advice
    Walter
  9. Re: Radio reception problems Mk5 Golf 2004 rcd300
    #19
    Jan 2019
    Uk
    Hi i have a mk5 1.9tdi estate, im trying to find were the aerial amplifier is located, any help appreciated.
  1. VW Golf Mk5 RCD300 died?!
    By robbeeston in forum In Car Entertainment
    Last Post: 19-09-2010, 08:16 PM
  2. Windscreen replaced and now radio reception problems!
    By essexexpat in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-03-2010, 09:11 PM
  3. Please Help RCD300 dreadful reception - MY04 Golf GT Tdi
    By Kav4962 in forum Golf MK5 - 2004 - 2009
    Last Post: 03-10-2009, 05:26 PM
  4. Please Help Radio reception problems
    By Goulders in forum In Car Entertainment
    Last Post: 01-01-2009, 09:12 PM
  5. Vw Golf Mk5 Rcd300 Cd Player
    By TANKSTER in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-06-2007, 03:27 AM
