Thread: 3.0tdi quattro wont start
Page 1 of 3 123 LastLast
Results 1 to 10 of 24
  1. 3.0tdi quattro wont start
    Apr 2009
    Hi,parked the car this morning A6 C6 3.0tdi quatttro,and when returning put the key in ignition turned it and Nothing,alarm works,central locking,interior lights and radio,but no dash lights absolutely dead.
    Called out RAC guy checked battery(fully charged),fuses all appear ok and tried jump leads,spare key still nothing,getting it recovered in ,morning to independant Audi dealer,but any ideas in the meantime.
  2. Re: 3.0tdi quattro wont start
    Oct 2011
    Devon
    My A6/C6 3.0TDI Quattro used to have the odd moment when it seemed to be dead. It happened maybe every 3 months or so, and there didn't seem to be any particular set of circumstances in common except that it was usually from a cold start. You turned it on, tried to start, and nothing happened. I found that turning it off, leaving it for a short while (10sec?) and trying again always worked although it maybe needed a second retry occasionally. Never did find out what the problem was as it always cleared itself. Maybe an issue with the immobiliser not recognising the key first time round?
  3. Re: 3.0tdi quattro wont start
    Southern County Softy
    20 Post(s)
    is it auto ?
    could be the inhibitor swith on the gear selector
    Does it need the brakes on to start, could be a failed brake light switch.
    A4 2.5 tdi QS (mapped)
    2 1 0
  4. Re: 3.0tdi quattro wont start
    Apr 2009
    Hi,thanks for the reply,it is auto and I can't remember if the brakes are required or not. I have read an american article where it seems a guy had the same issue and it may be a module linked to the ignition switch a guy over there had it replaced and the keys re-coded and he says that cured it. It should be with my local specialist by 9.30 in morning so fingers crossed,just trying to find the button thats supposed to be under the ashtray in order to move the gear selector from park to neutral,don't seem to be there.
    Ian
  5. Re: 3.0tdi quattro wont start
    20 Post(s)
    try turning the key pressing the brake and wiggle the gear selector all at the same time
  6. Re: 3.0tdi quattro wont start
    Apr 2009
    Hi,just an update re the starting issue,it turns out to be the Start,Access and Authorisation Module which turns out is an integral part of the steering colum which means the steering colum has to be replaced and is in the dealers now(who have been by the way fantastic) and should be back on the road early next week.
    Had an aftermarket warranty (RAC Gold Plan) and of course the unit is not covered,I really wonder if any of these warranties are worth the paper they are written on,but it won't be left at their refusal,more to follow.
    Thanks for the assistance.
  7. Re: 3.0tdi quattro wont start
    Aug 2015
    Wigan uk
    I had the same problem with my Audi Q7 3.0tdi
    when I put a volt meter on one of glow plug leads turned on the ignition nothing..
    i disconnected the the coolant temp sensor and bingo
    the glow plug leads reading 1.72volts,
    changed the coolant sensor and now car starts first time every time.
    coolant sensor is located at rear of right side of engine under the pipe for mass air flow pipe,
    you have to remove the black plastic housing bolted to turbo with 2 size 30 star drive set screws
    the sensor in located below, there a clip that holds the sensor in.
    you can't see the sensor until all pipe work as been removed..
  8. Re: 3.0tdi quattro wont start
    Nov 2012
    Somerset UK
    Remember to ask them for the old unit back, and also (since I'm assuming you're paying for it?) a printed scan of the car.
    No idea where you or your fantastic dealer is located since you don't have a location listed...probably a good idea for the future as that way local forum users with VCDS could have run a free scan for you
  9. Re: 3.0tdi quattro wont start
    Aug 2015
    Wigan uk
    Fitted the part my self as I am an HGV fitter and also I have a diagnostic lap top
    No faults codes showing
    Comment is to advise other's with the same problem
    away start by checking the cheapest first
    Tony
  10. Re: 3.0tdi quattro wont start
    Mar 2013
    Lincolnshire
    For future reference if it was an immobiliser problem it would still turn over but not fire IIRC
    A6 2008 57 Reg 2.7TDi SE Tiptronic Avant Quattro
  1. A4 1.9TDI 130hp 2002 Quattro Wont start
    By A4flyer in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 08-01-2011, 03:32 PM
  2. a4 1.9 tdi quattro wont start after accident
    By a419tdiquattro in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-03-2010, 02:40 PM
  3. Important HELP! - 2004 Audi A4 1.8t Quattro (B6) wont start!!!
    By skyline-sl in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-06-2009, 01:03 AM
  4. Please Help A4 2.5 tdi quattro sp wont start!!!
    By phall10 in forum Chat - Anything with wheels
    Last Post: 29-11-2008, 04:18 AM
  5. A6 05 2.0TDI Major Problems - wont start
    By jazz rana in forum Archive posts
    Last Post: 29-11-2007, 07:46 PM
