Thread: Diesel won't restart once the engine is hot?
  1. Unhappy Diesel won't restart once the engine is hot?
    Dec 2011
    Manchester
    Hi folks
    My passat diesel has developed a fault. Basically once it has been run for some time and the engine is hot it will not restart. The engine turns over fine and sometimes feels like it is about to start but just doesn't "catch"
    Eventaually it does usually start but it is a nightmare and very embarrasing.
    If I allow it to stand and cool down for a while (10-15mins) it starts no problem and it always starts first time from cold.
    The car has done 45k and been well looked after.
    I am sure other people must have had this problem?
    Can anyone give me some advice please
    Cheers.
    Jul 2008
    Bristol
    Possible faults from my experience. Immobiliser, maf sensor, egr valve.
    HTH!
    For Sale: VW Passat 2.0 TDI Sport
  3. Re: Diesel won't restart once the engine is hot?
    Norfolk
    You need a code read, guessing is pointless. If there are no codes, suspect the fuel system as in tandem pump fault or lift pump fault.
  4. Re: Diesel won't restart once the engine is hot?
    Nov 2012
    Ware UK
    Mikegarf - did you figure this out? My Passat has same symptoms
  1. Please Help !.9tdi Diesel Long Cranking when Hot
    By golf+5 in forum Golf MK5 - 2004 - 2009
    Last Post: 26-01-2011, 07:50 PM
  2. Question Hot restart
    By dr.jeep413 in forum Chat - Anything with wheels
    Last Post: 28-11-2008, 04:05 PM
  3. 2.5 TDi V6 Engine Cut Out Wont Restart
    By iain77 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-07-2008, 01:48 PM
  4. fault codes + loss of power until engine restart
    By churp in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-06-2008, 12:15 AM
  5. polo diesel 96, starting probs when hot
    By lanius in forum Polo - Derby - Lupo - Fox
    Last Post: 26-11-2007, 11:15 PM
