Thread: Parking Break Fault.
Results 1 to 10 of 10
  1. Parking Break Fault.
    Glasgow
    Yip another one. the fault code only came on today "Parking Brake Fault", and will still release the calipers......... am i on borrowed time, or do u tink it could be the switch as it is allowing the calipers to release. The Motors do make a hell of noise when the EPB is engaged, disengaged. Any help appreciated.
  2. Re: Parking Break Fault.
    Sep 2008
    Glasgow
    The switch is certainly the cheapest option, about £25 from the dealer and 2 minutes to change. I was the same last winter and I ended up changing both calipers.
    If you have a torx set I would take off the motors and check them for cracking which has been the problem for most people.
    Look at Martins site.
    http://sites.google.com/site/1810mar...ric-park-brake
    He gives a really easy to follow guide on the brakes.
    HTH
  3. Re: Parking Break Fault.
    Glasgow
    Defo not the switch. Was in VW dealership getting prices for replacement, after the shock of the £834 quote i went outside and started chatting to one of there mechanics. I decided, lets play with fire, and let him hear the noise that the brakes made. After making a funny face he agreed with me that it is goosed. So then went to drive away, and the thing packed in, flashing lights on dashboard and stuck solid. Luckily it managed to free itself after 5 minutes of consantly playing with the parking button.
    BAH HUMBUG lol
  4. Re: Parking Break Fault.
    Sep 2008
    Glasgow
    I assume that price is for 2 new calipers fitted? They aren't that difficult to replace. How much are they charging for labour out of interest. I think I paid about £600 for the calipers and then fitted them myself.
    Glasgow
    Thats for 2 motors, and labour, no calipers just the motors!! I Thot it was fairly steep, think I'll try another vw dealer!
  6. Re: Parking Break Fault.
    Sep 2008
    Glasgow
    The motors I think are around £200 each, I couldn't get them and put on the full caliper with motor attached. That sounds really expensive. What dealer quoted you? I got the complete units from Arnold Clark VW in Fenwick Rd. I did get a discount as my brother has an account with them.
    Glasgow
    That's the feckin place I got quoted, stay in shawlands so was the closest! Since u bought the calipers complete with the parking motor, did u have to use the vcds software to configure the piston etc?? Or did u just stick the calipers on and that was it!??
  8. Re: Parking Break Fault.
    Sep 2008
    Glasgow
    I stay in the Mearns. I am lucky that I was a mechanic years ago and my brother has his own garage in Troon with the equipment to reset the computer.
    If you are just changing the motors then you won't need to reset the pistons to there service position as they will already be there. You might be lucky after replacing the motors, disconnect the battery and when the system resets with any luck it wont detect a fault.
    The motors are only held on by 2 torx bolts and the wiring connector. You could easily do it yourself if you don't mind trying. Give me a PM if you need any more help or advice. If you want I could try and get a quote through my brother for the parts but it would be next week now as he is closed for a few days.
    Glasgow
    Shall pm in a bit or so!!
  10. Re: Parking Break Fault.
    My problem started same way.After a couple of weeks of intermittent operation the brakes finally stuck on... Result was a new Electronic module for £400,fitted. I had new calipers fitted by dealer (complete with disc & pads) some three weeks earlier for £980. I just love electronics..
  1. Please Help Parking break light blinking and beeping when rains and after??????
    By ludikris in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-08-2011, 06:05 AM
  2. A6 Alarm problem along with ESP & Parking Break malfunction
    By bobbymclov in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 28-05-2011, 01:46 PM
  3. Please Help Parking Brake Fault
    By EGoodier in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 12-02-2011, 01:05 AM
  4. Please Help Parking Brake Fault..........
    By smiggy9 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 14-07-2010, 11:11 AM
  5. Parking Brake Fault
    By reddb990 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 13-01-2009, 02:36 PM
