Thread: Fault code 19463
  1. Fault code 19463
    Apr 2009
    scotland
    I have fault code 19463 , camshaft positioning sensor , car is struggling to start glow plugs have been just renewed had fault codes for them now gone , But have this 19463 bugger up , any idea where it is , and is it easy to replace
  2. Re: Fault code 19463
    May 2010
    Devon England
    if its a 1.9 TDI the camshaft sensor is under the top cam belt cover by the camshaft sprocket
    VCDS HEX+CAN CODE READING AND RECODES
    OWN A MK5 GOLF TDI JOIN THE GROUP https://www.vwaudiforum.co.uk/forum/group.php?groupid=23
    2004 mk5, Viezu 140bhp Re-map, GTI front bumper, side skirts, GTI 18in rep wheels, Jamex coilovers, R32 speedo cluster, MFSW, White Roose Motorsport coolant hose's, GTTDI interior, centre consol armrest and ipod dock, leather handbrake lever
  3. Re: Fault code 19463
    Apr 2009
    scotland
    1.9 tdi , can this affect the starting of the car ,
  4. Re: Fault code 19463
    May 2010
    Devon England
    yes the camshaft sensor can effect starting as the sensor tells the ECU where it is (if you follow me) i dont think its a bad job to change it, the crank sensor is the nightmare to change tho
  5. Re: Fault code 19463
    Apr 2009
    scotland
    Hi Phil changed sensor today but still have that fault code 19463 coming up and car still trying to start , where is the fuses to this ,
  6. Re: Fault code 19463
    May 2010
    Devon England
    If you have replaced the sensor with a new VW item and the code is still there i would then check the wiring for the sensor back to the ecu, iirc the ecu is under the scuttle panel and it's not unheard of for moisture to corrode the terminals and throw up error codes, if you need an ecu wiring diagram post up your cars age and engine code and I will post it up mate
  7. Re: Fault code 19463
    Apr 2009
    scotland
    Hi Phil , i bought the sensor from a motor factor its not a genuine VW one £16 . The Vw one was £85 from dealer could this be the problem , Is there a a way to test the power from the sensor .
  8. Re: Fault code 19463
    May 2010
    Devon England
    I think your next step should be to check you have power there with a multi meter and check the wiring for continuity to check that no wiring is broken if you need a wiring diagram I can email you one
  9. Re: Fault code 19463
    Jul 2019
    Combe Martin
    Hi Phil hope you are still an active member. I have the same problem after installing a reconditioned engine. The ODIS software is coming up the 19465 Camshaft position sensor no signal. Have you or can you point me to a set of wiring diagrams that will enable me to chech whether the fault is the sensor, the fuse (not sure which one it is within the engine control fuse box, it says 7E/7F in the test plan) or a wiring problem. Thanks in advance
    Duncan
  1. Replies: 6
    Last Post: 10-05-2011, 11:03 AM
  2. VAGCOM Fault Code 00588 - Airbag fault
    By headache56 in forum VCDS - General Questions
    Last Post: 31-01-2009, 01:05 PM
  3. Question AIRBAG FAULT warning light and VAGCOM Fault Code 00588
    Last Post: 16-01-2009, 06:05 PM
  4. Vw Dtc 19463
    By Delco in forum Polo - Derby - Lupo - Fox
    Last Post: 20-11-2008, 11:05 AM
  5. Replies: 0
    Last Post: 15-01-2008, 01:07 AM
