Thread: My 16v coupe just wont start.
  1. My 16v coupe just wont start.
    Dec 2011
    Stockport,England
    Hello to all,i am new to this forum so i may aswell start with an awkward problem.
    I have a 1993 2.0 16v coupe with 220,000 miles on the clock although i have completely rebuilt the engine in the past six months or so.
    Just last week after running fine with no signs at all i came to start the car one morning and nothing happened-no cranking,no fuel pump priming and no starter turning.The battery was six years old so i decided to stick in a new one.Still the same!
    i noticed that only the abs light came on along with the handbrake light also when turning the ignition key but none of the others-strange? i assumed that the culprit was the ignition switch and so changed that too,a cheapo one off ebay for £7-still the same but this time the red circle with exclamation mark inside it light(fluid?) now comes along with the others but no sign of the battery/oil and whatever else comes on when you turn the key.the spigot inside the ignition barrel was fine so i can rule that out and the car wont start with a jump lead so i think the battery side of things is fine plus the fact all of the power related stuff still works radio/windows etc.
    Can anyone relate this to a similar problem they might of had or point me in some kind of direction 'cos its too damn cold to be poncing around for long in this weather and i need a quick fix.
    thanks Rob
  2. Re: My 16v coupe just wont start.
    Sep 2011
    Isle of Man
    the best way to get an answer in the forums is by structuring your question, a suggested format:
    inform us what precisely happens when you turn the key!
    what light(s) come one if any, and if the engine cranks at all. personally i would call the AA out and get them to try get it going, it may be something fundamental that is causing you problems like a faulty wire or terminal.
    relay that information back here and we will do our best to assist your further.
  1. My 16v just wont start.
    By robonmac in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 09-12-2011, 03:08 PM
  2. 16v coupe no spark
    By lenny-vw in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 10-02-2010, 06:39 PM
  3. HELP PLEASE!!! 1988 Mk2 16v wont start
    By Blackberry in forum Golf MK2 - 1984 - 1992
    Last Post: 07-07-2009, 12:39 PM
  4. mk2 16v wont start?
    By tommy_v in forum Golf MK2 - 1984 - 1992
    Last Post: 31-12-2008, 05:17 PM
  5. audi 80 coupe wont start?
    By the1pongo in forum 80 - 90
    Last Post: 28-05-2008, 12:02 AM
