Thread: Drivers reversing lamp showing gone on dash but no blown lamp in cluster
  1. Drivers reversing lamp showing gone on dash but no blown lamp in cluster
    Nov 2008
    Frizington, Cumbria
    Can anyone help
  2. Re: Drivers reversing lamp showing gone on dash but no blown lamp in cluster
    Sep 2008
    chester
    17 Post(s)
    Do a continuity test on the bulb,dont trust a visual.
  3. Re: Drivers reversing lamp showing gone on dash but no blown lamp in cluster
    46 Post(s)
    Check the cluster for corrosion, loose connections etc. My A6 had a fault where the connections on the bulb holder were corroded and the connection was lost between the bulb and the connection thus throwing the bulb warning on the dash.
  4. Re: Drivers reversing lamp showing gone on dash but no blown lamp in cluster
    Nov 2011
    Swansea, South Wales
    if the 'bulb blown' sensor system is anywhere near as sensitive as my 320d, it can sense that a bulb is 'about' to fail.
    several times now the dash has warned me, but all lights are working - within two weeks a bulb has actually failed!!
    change the bulb and see if warning goes away - or wait until one fails!!
  5. Re: Drivers reversing lamp showing gone on dash but no blown lamp in cluster
    Southern County Softy
    20 Post(s)
    change the bulb and while your in there clean all connections.
    A4 2.5 tdi QS (mapped)
  1. Sharan drivers side rear reverse lamp wont light up
    By sharan1.9 in forum Touran - Sharan - Caravelle
    Last Post: 15-03-2023, 11:23 PM
  2. Replies: 4
    Last Post: 21-07-2010, 09:10 PM
  3. Question Mil lamp
    By greros1 in forum Polo - Derby - Lupo - Fox
    Last Post: 12-05-2009, 06:47 PM
  4. Head lamp problem
    By badade 1.8t in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-04-2009, 06:46 PM
  5. polo abs lamp
    By carrotts in forum Polo - Derby - Lupo - Fox
    Last Post: 28-12-2007, 06:07 PM
