Thread: Engine mount solenoid code 17996
Results 1 to 10 of 10
  1. Engine mount solenoid code 17996
    Dec 2008
    My car is throwing up this code: 17996 Engine mount solenoid valves Open circuit
    Does this mean that my engine mounts are worn? How many are there and how easy can they be changed?
    55 Audi A3 1.9 TDI 105 se....frugal
  2. Re: Engine mount solenoid code 17996
    Ardfern
    8 Post(s)
    Presumably you have no symptoms?
    I have 17994 short to plus intermittent but I have not identified any related symptoms.
    I'd be interested in any suggestions for a cure.
  3. Re: Engine mount solenoid code 17996
    Dec 2008
    No major symptoms I dont think, maybe theres a bit of shake from the engine now and again, I would have to replace them and then see if there was any difference after. Im assuming that the mounts are just getting worn after 10 years, understandable I guess.
  4. Re: Engine mount solenoid code 17996
    Mar 2011
    Kendal Cumbria UK
    The A4 has electrohydraulic mounts, that adjust stiffness according to engine load to minimise movement to maximise torque transfer, i dont know what detrimental effects a worn/broken mount would cause tbh, as it still acts as a mount, just doesnt change its stiffness.
    Dan
    2002 A4 B6 2.5 TDI Quattro Sport - Mods to date... Too Many To List!
  5. Re: Engine mount solenoid code 17996
    Nov 2008
    N/A
    Never understood how engine mounts work until the above post!
  6. Re: Engine mount solenoid code 17996
    Dec 2008
    Very interesting!
  7. Re: Engine mount solenoid code 17996
    Mar 2011
    Kendal Cumbria UK
    I dont know how common they are, a normal engine mount is just a rubber block bonded to an alloy mount to take out engine vibrations and allow it to move a bit under torque, the A4 (and probably other audis) have this electrohydraulic one, which i assume is either like a damper (shock absorber, although that is an incorrect name for them, the spring is technically the shock absorber in your suspension!) with oil inside and electronic valving to restrict the oils flow, or a magnetic hydraulic fluid, like an oil with metal in it, which changed viscosity with the strength of a magnetic field applied to it.
    Dan
  8. Re: Engine mount solenoid code 17996
    Sep 2008
    chester
    17 Post(s)
    Its a very common fault code,unless you have serious vibration ignore it!
  9. Re: Engine mount solenoid code 17996
    Jul 2009
    Sheffield
    I replaced mine when this fault was flagged up,didnt appear to make a difference.
  10. Re: Engine mount solenoid code 17996
    Dec 2011
    Swindon
    9 Post(s)
    How do you scan this using vcds? A step by step guide would be useful
  1. Fault code 17994 - Engine mount valve, what is it?
    By GeorgeE in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 29-05-2011, 06:12 PM
  2. turbo blown??? code 17552 17996 17569
    By nickeym1 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-05-2010, 08:14 PM
  3. engine mount solenoid valves
    By kangtdi in forum VCDS - General Questions
    Last Post: 09-12-2009, 05:20 AM
  4. engine mount solenoid nalve
    By coupe2 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-09-2008, 07:25 AM
  5. Fault Code PO411 - Secondary Air Solenoid Valve (SASV Y75)
    By andyaudia4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-06-2008, 07:32 PM
